Eaton M112 Supercharger Drain Plug
Old Sep 27, 2022 | 02:34 PM
LausDeMaus's Avatar
Default Eaton M112 Supercharger Drain Plug
Hi Guys,
Am struggling to find a replacement for drain plug, am in the UK and cant seem to find any within Europe, only america. Would anyone know where I could get one or even the specs for the drain plug. Its off an 05 XKR
Jack
Old Sep 27, 2022 | 03:50 PM
JagV8's Avatar
Can't you reuse it?
Old Sep 27, 2022 | 04:48 PM
LausDeMaus's Avatar
I can't it was stripped
Old Sep 27, 2022 | 08:08 PM
watto700's Avatar
G'day Jack,
Could you tap a thread in the hole and use a different sized bolt? Or maybe use a Helicoil.
Cheers,
Jeff.
Old Sep 28, 2022 | 05:04 AM
LausDeMaus's Avatar
Hi Jeff
The treads are fine, stripped was probably the wrong word. The hex slot was rounded.
I found this one, would it do the job?
https://www.hydraulicmegastore.com/p...iABEgK76fD_BwE
Jack
Old Sep 28, 2022 | 04:04 PM
JagV8's Avatar
Scrap (breaker) yards will have them.
Old Sep 29, 2022 | 08:43 AM
clubairth1's Avatar
Community Influencer
Since your in the UK and we are mostly in the US my normal parts supplies will do you no good?
Have you contacted these guys?
M112 Service
They seem to have a wide selection of stuff and they also rebuild these units so I would think they should have one or more laying about. I still can't figure out how this would be damaged as the blower is Aluminum and the bolt is steel?
Old Sep 30, 2022 | 02:03 PM
xalty's Avatar
get a caliper and then a thread pitch gauge and you're good to go... you guys abandoned american fasteners so online might be the only way
Ant Buck
Jul 18, 2022 11:01 AM
KyleB
Jan 23, 2022 07:06 AM
mrtwill
Aug 4, 2016 09:38 AM
gtmaster303
Sep 14, 2014 08:02 AM
aviation14
Sep 9, 2014 03:57 AM
