Failing Oxygen Sensor Orientation Test
Old Jan 14, 2015 | 08:28 AM
Vee's Avatar
Vee
Default Failing Oxygen Sensor Orientation Test
I have a 96 XJS.
I am trying to complete an oxygen sensor orientation using a Mongoose and IDS v134. Everything goes well until about 70% into the process where it ends abruptly and tells me I've failed.
What can cause this?
The oxygen sensors are about 6 months old.
I did replace the exhaust manifolds, and I can't detect a leak. I managed to torque the manifolds against the block to 50 Nm, the front downpipe was torqued to 30Nm. I ended up stripping the bolts to the rear downpipe before I could get to 30Nm, but again, no leak detected.
Old Jul 27, 2023 | 10:02 AM
Bobgee's Avatar
Originally Posted by Vee
I have a 96 XJS.
Do you know what was wrong, I try the same but it doesn't work in IDS :-(
Old Jul 27, 2023 | 10:17 AM
Vee's Avatar
Vee
Back then, I was using an aftermarket mongoose to perform this adaptation.
Either to software crapped out, or the ECU did. If I had to bet, I believe the mongoose clone did something the ECU didn't like and screwed up my ECU. An eventual ECU replacement solved my problem.
I never used the cloned mongoose again. (It did work a few times)
XJR_hunter
Apr 8, 2024 09:21 AM
Canadacat
Dec 10, 2019 01:27 PM
kurtomatic
Oct 23, 2015 11:57 AM
edtexas
Apr 5, 2013 02:50 AM
globalgrooves
Apr 4, 2010 01:21 AM
