Fuel injector relay not disconnecting
Old Feb 22, 2016 | 11:16 PM
OMGPirate's Avatar
Default Fuel injector relay not disconnecting
How can I get this piece off? Ive been trying with a flathead, but Im also not sure Im prying in the right area for get it disconnected. This is on an 82 xj6, not that it matters Im sure.
Old Feb 22, 2016 | 11:57 PM
OH boy, British Non-Metallic, good luck.
They are a MONGREL at best.
I would get some p/pack carby cleaner or Brakeclean, and clean all that gunge off first, then soak it in WD40, or similar, then keep at it. The blade is the only way I know of. Pulling on the wires will break them.
I have been known to cut that nonsense out, frustration does that, and fit a "normal" loom connector, that has a simple tab to push to seperate the 2 halves. Down here we have Narva as a connector etc supplier, and readily available near everywhere.
Old Feb 23, 2016 | 02:30 AM
Clean it up first so you can see what you're doing. One of the few things that WD40 actually will do.
It's a very long time since I had a 'series' XJ6 and the memory dims but is there a securing screw in one end of this pattern connector?
Members with more recent experience will either nod in agreement or call me a muppet depending on how good my memory is!
Old Feb 23, 2016 | 05:32 AM
Nope.
Brute force, dumb luck, much foul language, blood letting (when the blade sips), and finally cutting the wires and starting over.
Something I dont miss, trust me.
Old Feb 23, 2016 | 06:05 AM
Doug's Avatar
They come apart by wiggling and twisting.
I'll often use pliers on each half of the connector to increase the oomph of my wiggling and twisting.
Mind you, you're not trying to squish the bejesus out of the poor things. Use just enough pressure with the pliers to grip the plastic and then twist a bit. They'll come right apart. It's all in the wrists
Works every time!
Old Feb 23, 2016 | 01:04 PM
OMGPirate's Avatar
Originally Posted by Grant Francis
Nope.
hahaha there was much foul language just getting to that point already. Im really trying to avoid removing the hose that it is under.
Thank you for the help everyone!
Assisi15
Mar 14, 2016 07:17 PM
lfjeff
Feb 13, 2016 01:38 PM
Rick25
Feb 8, 2016 11:53 AM
Uziel
Jan 30, 2016 06:18 PM
