Help
Old Dec 13, 2023 | 12:57 AM
Adam Brackett's Avatar
Default Help
I just inherated a 2007 jaguar s type. It has no key I don't even no if it runs . They want 980$ for key but I don't want to spend that if the car is junk is there any way to start the car without spending a thousand dollars so I will no if it is worth putting the money into it
Old Dec 13, 2023 | 02:44 AM
Welcome to teh Forums.
I doubt it.
Your USA market would have systems that require key recognition to activate the brains that work the car.
I suggest a re-ask in the S Type (X200) Tech Section, maybe I be wrong.
Good luck.
Old Dec 13, 2023 | 05:17 AM
Welcome to the forum Adam,
As Grant says, the key is coded to the vehicle. Members in S-Type forum will be able to suggest lower cost sources or options but that is likely only to be the start of your troubles. If the vehicle has not been run recently then dead battery and stale fuel are just two of the issues you will encounter. Unless you really want the vehicle and are prepared to spend what could be more than it's worth to get it running, then disposal is the sensible action.
If you do want to keep it and get it running, all the necessary help and advice is available here in S-Type forum.
Rascal
Mar 2, 2018 02:49 AM
IXLLER8
Apr 19, 2017 10:44 PM
AbyJag
Dec 1, 2016 09:09 AM
mcook
Jul 19, 2014 06:58 PM
tford
Mar 23, 2011 09:35 AM
