How to write a value using OBD2 bus into an ECU
Old Mar 8, 2021 | 05:15 PM
dernotte's Avatar
Default How to write a value using OBD2 bus into an ECU
Hi,
I have scanned quite extensively the OBD2 bus and discovered a few ECU. I have also identified a few PID on those ECU. Now it is time to write value into those PID, and see if I can act on the car (power on the car, lock on and off door, open/close windows, etc...) to start with. I have access to the proximity sensors, the throttle position, and gear shift, so maybe that will be possible to recreate a "summon" mode. Since the vaste majority of the PID are non standard EPA PID, I need to query them with the 0x22 mode. I am struggling with the write mode. How can I write a value to a PID. I've read that the 0x2E mode is use to write, but I have an error on the bus with this mode. Does anyone successfully wrote a value in a PID on the CAN bus ?
Old Mar 9, 2021 | 07:01 AM
JagV8's Avatar
If lucky you will not be able to do that. If unlucky you will brick your car and need an OE tool to get back a working car - if you can unbrick it at all.
jamesoliver
Oct 27, 2018 07:19 PM
swetnK
Sep 24, 2015 07:55 AM
David N. Warner
Apr 29, 2015 12:58 AM
peter.f.jones
Jan 28, 2014 06:16 AM
CJNetrider
Sep 13, 2012 06:15 AM
