Looking for General Advice on Valve Cover Gasket Replacement
Old Sep 5, 2012 | 06:39 PM
OldMike's Avatar
Default Looking for General Advice on Valve Cover Gasket Replacement
I changed my plugs a few months ago and there was some, not much, oil on the threads of all the plugs, not much but some. I didn't see any pooling inside where the plug goes, so I didn't get too worried.
I've heard that a little oil isn't unheard of and shouldn't cause any panic, but I was wondering what everyone's advice is about this.
I have a good mechanic who will do the work for me (or I could do it myself), buying the gaskets and plug seals isn't an issue, I'm just curious as to what amount of oil would raise a concern for you. Any oil?
Thanks.
BTW As you can see in my signature - I have an 03 XJ8 and it runs beautifully.
Old Sep 5, 2012 | 06:43 PM
WhiteXKR's Avatar
It is certainly no emergency, but it should be addressed. Enough oil in the wells will eventually cause misfiring. Leaking seals generally get worse as time goes on.
Old Sep 5, 2012 | 09:57 PM
OldMike's Avatar
Thanks, I was thinking along those lines. Not smart to just ignore it.
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
Bcrary3
Aug 31, 2015 11:29 AM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
