Lower oil pan gasket leak
Can anyone advise me as to how hard it is to change a lower oil pan gasket, I have a leak onmy 1998 XJ8 and my mechanic advises replacing it. Any specialist tools required?
Thanks,
Michigan.
Thanks,
Michigan.
will your there replace the4 orings 2 inches above the oil pan in the front of the engine .. the orings are blocked by a plate i think 13 mm .. they also give false oil pan gasket leaks
aholbro1
Dec 29, 2024 06:46 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
