Need a Floor Shifter Gear Selector Indicator Module
Old Aug 23, 2024 | 02:00 PM
SeanXK8's Avatar
Default Need a Floor Shifter Gear Selector Indicator Module
Good day All,
I have a quick question and was looking for a bit of help. I have a 1999 XK8, and my Floor Shifter Gear Selector Indicator Module, P/N# Lja6195Bf, is cracked in half. Does anyone know how I can get one?
Thanks,
Sean
Old Aug 23, 2024 | 05:40 PM
watto700's Avatar
G'day Sean,
Google the part number and you will find loads of them.
Cheers,
Jeff.
Old Aug 23, 2024 | 06:12 PM
motorcarman's Avatar
A SuperCharged Gear Selector Illumination Module will not work.
Any 4.0 liter ZF 5HP24 module from an X100 or X308 should work fine.
Old Sep 6, 2024 | 03:50 PM
SeanXK8's Avatar
Thanks Jeff,
Can you share a link? I've been looking around and all I can find is the gear shifter assembly for a couple hundred dollars. All I need is that flat black plastic disk-like piece.
Regards,
Sean
Old Sep 6, 2024 | 04:18 PM
The problem is that the D4 switch cam plate is NSS. (not sold or serviced separately)
It is part of the gear selector illumination module.
Old Sep 18, 2024 | 01:15 PM
SeanXK8's Avatar
Thanks Motorcarman, I figured that but was hoping to catch a break.
Old Sep 19, 2024 | 04:08 PM
Technically you don't need the cam plate if you NEVER shift into the lower gears. (just the right side on the selector)
oldgeezer2015
Sep 8, 2023 04:10 PM
Fad-Jag
XF (X260)
Sep 3, 2020 07:22 AM
PatrickO
General Tech Help
Apr 17, 2018 07:18 PM
kmschaer
Mar 30, 2015 07:16 AM
