OBDII Code Scanners ** Member Approved **
Old Apr 26, 2018 | 08:38 PM
  #521
RonaldP's Avatar
Has anyone used the iCarsoft i930 on a 1999 XJ8 or a 1996 XJS?
Old Apr 26, 2018 | 11:02 PM
  #522
Robman25's Avatar
Yes on my 1999 XJR it is the dedicated Jaguar/landrover one.I have just need to learn how to evaluate the information, also tried it on a friends X308 1998 which was playing up, the iCar did not return any DTC’s but was later diagnosed with misfire on No 8 plug. Changed out the coil and all go again. Unfortunately I did not have my other scan tool with me as I feel this would have returned the DTC.
Old Apr 27, 2018 | 07:13 AM
  #523
rsdmitch7's Avatar
Smile Innova Web Site
Originally Posted by cheebong
Whew! I've read through this thread, starting with page 1. I have a 2002 Jaguar X Type 3.0 and the check engine light just came on.
I've narrowed it down to Roadi NGS100, Actron Cp9550 PocektScan Plus, Innova 3030g and Innova3030. Which should I get? I need one that will reset the light, too.
I've looked at the Innova web site. I registered and was able to enter my codes under Jaguar and the definitions came right up. It's Free. I saved the site. I thought it was very helpful
Good Luck
Mitch
Old Apr 27, 2018 | 10:56 PM
  #524
jimlombardi's Avatar
RonaldP
I have been using the on iCarsoft i930 code scanner our 2001 XJ8. Purchased it in 1/5/2015 $120.00 special price - was on Ebay for $139.95
I used it a lot of times in 2015 thru 2016. Mostly to remove error codes especially ones that limited speed down to 15 mph (restricted performace)..
As I remember it is able to read the ABS brake system pretty well.
I have not tried to update the software for a long time.
No issues with 2001 XJ8 since end of 2016, Thank goodness, but I do have the code scanner in the boot.
Old Apr 28, 2018 | 06:25 AM
  #525
Wingrider's Avatar
My iCarsoft i930 was purchased for about $60 delivered. Best price available, $50 off the first order, with an Amazon credit card application. Works on my 07 a little better than my 04, but it works on both, & clears the codes.
Old Apr 30, 2018 | 10:49 AM
  #526
Jaguar EU's Avatar
Hi,
Anybody tried this one?
VXDIAG Nano VCX
Old Apr 30, 2018 | 12:52 PM
  #527
JagJoe80's Avatar
RonaldP
Hi
I bought the icarsoft i930 and it works perfectly on my three cars:-
1999 XJ (X308)LWB
2005 X Type
1998 XK8
Any further info just ask.
Good luck.
Old May 22, 2018 | 03:50 AM
  #528
AUDEW's Avatar
Innova 3030 performs well. This is an excellent tool for the DIY mechanic or layman. It is plug and play with more information made available than I expected. All the information displayed is also explained in text on the tool for easy understanding. With one service diagnostic use, it pays for itself. Even if your check engine light is not currently on, it can retrieve intermittent faults that previously turned on your check engine light if they are stored in your vehicles memory.
Old Jun 7, 2018 | 03:21 PM
  #529
dbtk44's Avatar
I've been using a cheapo ELM327 bluetooth module ( $12-15 on Amazon or Ebay ) and the paid version of Torque ( $4.95 ) on my phone,
and it clears all codes and turns the check engine light off, within about 5-10 seconds ( I always save a log of the error codes so I have something to refer back to if I need it ). I'm actually pretty impressed with Torque..was using the free one and was decidedly NOT impressed, however the paid version is a whole different world. Definitely well worth $4.95, and provides a surprising amount of info and functionality.
Probably not as good as a dedicated OBDII scanner...but, I had the ELM327 already, and took all of 20 seconds to purchase and install Torque. Well worth the $20 or so total investment, in my opinion.
Old Jun 7, 2018 | 03:26 PM
  #530
rsdmitch7's Avatar
dbtk44; Thanks for the info. For $4.95 I'll definitely give it a try.
Mitch
Old Jun 7, 2018 | 08:45 PM
  #531
keplaa's Avatar
Thumbs up
Thanks for that dbtk44. It sounds like it is worth investing in the full version of torque, so I will !
Old Jun 22, 2018 | 02:09 PM
  #532
Flappers's Avatar
Hi all, can anyone please help.. I'm trying to open the log file from the tool I'm using - PCMSCAN - and Excel is just showing illegible symbols. Does anyone know how I can make this make sense, please ?
Old Aug 20, 2018 | 12:54 AM
  #533
RayR's Avatar
I use Kiwi PLX WiFi with my iPhone 6S.
Old Oct 29, 2018 | 06:59 PM
  #534
pajeff02's Avatar
Found out that the dealership charges $63 to reset the "Service Required" indicator after I changed the oil. Considering the LR V2.0 from iCarsoft as neither of my current scanners have this functionality. Anyone have experience with this model?
Old Oct 30, 2018 | 04:17 AM
  #535
Wingrider's Avatar
Page 413-09 A : Warning Devices
In the shop manual. gives you instructions on how this is accomplished.
Old Oct 30, 2018 | 05:47 AM
  #536
pajeff02's Avatar
Thank you. My current scanner is an Innova 3140e and it was able to connect and read codes on our 2018 XE 25t. I could also view live engine data, however, I was not able to access the enhanced functions. I did not try my older Actron scanner as it is a lower end model and was acquired maybe 10 years ago.
Old Oct 30, 2018 | 07:41 AM
  #537
Wingrider's Avatar
No scanner is needed; Just following the manuals procedure, pushing buttons on your car, is all that's required to reset things.
Old Oct 31, 2018 | 05:59 AM
  #538
pajeff02's Avatar
I see (thanks to this forum) that this is indeed an option. I will likely still acquire a scanner as I do all my own work on our cars and the XE will not be under warranty forever.
Old Oct 31, 2018 | 08:17 AM
  #539
Dan.B's Avatar
Be sure the scanner you pick works with your model. The ICarsoft i930 I bought won't read the ECU on my 2004 XJ8--their tech support has never gotten back to me after multiple tries.
Old Dec 23, 2018 | 11:51 AM
  #540
arkaussie's Avatar
Default iCarsoft LR V2.0 scanner
I looked thru this whole Thread and found no mention of this scanner. Plenty about the iCarsoft i930 but I need to be able to chase an airbag problem which really cuts out a lot of scanners. This one at $145 on ebay seems to be a good deal, ($250 i think on the corporate website) as it does so much more than the i930. My only problem is that no one has mentioned it and I was hoping to get some feedback from someone who has used one. For the record I have a 2002 XKR convertible.
