Oil Pressure Gauge
Old Feb 17, 2012 | 05:35 PM
XJ6 Continental's Avatar
Default Oil Pressure Gauge
Has anyone had an issue with their oil press. going irratic while driving?
Old Feb 17, 2012 | 06:16 PM
Is there a car involved?
Maybe you could give us some details.
Old Feb 18, 2012 | 08:51 AM
it for my 85 XJ6 I've noticed that when I am driving the oil pressure gauge jumps around between 0 and 50 normally when sitting at idle it is just below 40 and when driving it's generally just past 40 the last time it did this it was low on oil however i just topped it off so it has me a little concerned. Also I've noticed that I am loosing oil but I don't have a spot under the car so I can't figure out where or how I'm loosing oil all of the seals on my car have been replaced. Help
Old Feb 18, 2012 | 08:19 PM
motorcarman's Avatar
Does the OIL LIGHT (low pressure) come ON?????????
There are 2 'senders'. Oil pressure transducer and oil pressure switch.
Sounds like the transducer is failing????
bob gauff
Old Feb 19, 2012 | 10:22 AM
The oil light only came on once and the oil was low at that point other than that it hasn't come on. The switches that your describing where are they located?
Old Feb 19, 2012 | 02:47 PM
They are on the block, forward of the oil filter housing.
bob gauff
Old Sep 23, 2012 | 01:42 PM
Chris Willis's Avatar
Motorcarman, My problem is I can't find gauge sender. Top of oil filter has two hoses to radiator have dummy lite sender only have looked every where .?? Two pole sender ??
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
ccfulton
Sep 20, 2015 05:15 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
