Original Daimler nuts
Old Dec 19, 2024 | 10:57 PM
NJDM41's Avatar
Default Original Daimler nuts
Hello: Have a Daimler Super8 V8 2008 with only 32000 Km and Yokohama 8 y/o tires. Had new tires installed recently. Mechanic used pneumatic wrench to remove original nuts and broke one. Couldn’t find original, so installed ‘solid’ one-piece nut. Was warned other original nuts will fail eventually. From your experience with this car and its ’****-to fail’ nuts, is it wise to replace all original nuts to avoid problems? Will use of manual tire-wrench to remove and place nuts be better than the pneumatic?
Old Dec 20, 2024 | 06:25 AM
clubairth1's Avatar
Community Influencer
Yes. Many threads on this and those crappy sheet metal covered lug nuts are way too common and are used on many brands. I always replace them with solid lug nuts. Stainless Steel is best as the solid chrome plated ones will rust with time.
Here is a quick search that has 240 threads concerning lug nuts. Read a few and make your own decision.
Sheet Metal Covered Lug Nuts
Old Dec 20, 2024 | 08:22 AM
NJDM41's Avatar
Default Hints on lug nuts for Daimler Super8 2008
Hello: Thank you for prompt response to my inquiry on lug nuts for my car. I will follow your recommendations to prevent further problems. Best Regards and Marry Christmas 2024. Noel
miami jags
May 26, 2021 09:36 AM
MrWhite
33
Oct 22, 2015 10:29 AM
AntXJ
Oct 20, 2015 01:39 PM
WayneCountyBill
Oct 12, 2012 09:14 AM
Jon89
May 29, 2009 12:42 PM
