radio power on problem
Old Jul 2, 2014 | 09:34 AM
vicsrc's Avatar
Default radio power on problem
I have a 1998 VDP left drive with a strange problem.
When I park my car and turn off my key and remove it the radio or cd changer remains on and playing.
I push the off button on the radio and all turns off.
Sometimes the radio or cd will come back on by its self and remain on and run the battery down.
I have talked to my local jag tech and he has no idea as to what the problem is.
If you have any info as to where To look for this solution please lt me know.
Old Jul 2, 2014 | 10:37 AM
A PO has probably been messing with the wiring to enable the radio/CD to play without the ignition in position I or II by connecting it to a permanently live feed.
Removing the radio unit to check the harness connections at the back will show if the feed has been re-routed.
Old Jul 2, 2014 | 02:59 PM
MarathonJohn's Avatar
Default Radio code calling
I just joined, having given the local dealer and national Jag rep (Karmen in Jersey!) my vinYLF19803, my no. on the radio back, Model AJ2000w, LNF4100AA, or 020108(n18), and am waiting for phone contact from either for the radio code in order to play it after having unhooked the battery. Would it matter if the car was titled salvaged via a car fire before I got it? I've put 20k miles on it in two years. I got cam tensioner replacement and some cooling replacement from a Jag man's garage early and have driven in luxury, power, and style since. Pioneer style, I fix everything I can, using forums and internet info. Mechanical types mostly need info., tools, parts, and their own wits and determination to see a job through. Sites like these rock! I hope to add some helpful info in the future.
Old Jul 2, 2014 | 03:09 PM
OK, Karmen from Jersey just called with 6466. Punched in the number, now the face, after a beep, reads 'please wait.' I'm a learner so will search.
Old Jul 2, 2014 | 03:26 PM
vicsrc's Avatar
Default radio
I might not have been clear about the radio staying on but it does it only once in a while most of the time it will operate correctly and turn off with the key
Only once in a great while will it stay on when the the key is turned off and other times it will turn its self on by its self after being parked for hours.
At one time it had been parked for at least 6-7 hours and as I was working outside in the yard I saw the antenna go up and the radio start playing so I dont think its a bare wire.
Old Jul 2, 2014 | 03:59 PM
Thermo's Avatar
Veteran: Navy
vicsrc, it may be that due to the heat of Arizona and aging electronics, you may be experiencing the electronics failing in a rather unique way. I understand what you are experiencing and that is about the only thing that I can think of.
Old Jul 2, 2014 | 04:47 PM
vicsrc's Avatar
Default radio
Believe it or not I am inclined to agree with you about the electronics.
parked in my garage it gets to about 125-135 real easy
Today we are getting to 111 degrees and a metal garage gets real hot I am also thinking that if there is a relay that controls the entertainment package the contacts areflexing from the heat.
Yesterday was the first time in a year of owning my car that my cooling fans stayed on to cool the engine after stopping the car .
It gets pretty hot here and we see a lot of Caddys on the side of the roads steaming.
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
