Rear window detached from to[p
Old Aug 7, 2015 | 04:10 PM
Jonnyy's Avatar
Default Rear window detached from to[p
I have a XK7 convertible and found my rear window separated from the convertible top. It looks like it was glued together. Anyone know how to put it back together?!
Thanks,
Jonnyy
Old Aug 7, 2015 | 04:16 PM
WhiteXKR's Avatar
If you mean a 2007 XK this is a known problem. Jaguar even has a repair TSB on the issue which I have attached.
Unfortunately it is a common problem with bonded windows on convertible tops (not just Jaguar).
It can be repaired, even if it is worse that as described in the TSB. See the discussion on this topic here: https://www.jaguarforums.com/forum/x...ble-top-97478/. Some upholstery shops and some windshield shops might be willing to take it on. I think you will find though, that few will guarantee the repair, and they will only do it on a 'best effort' basis.
Next time post in the 2006 and later XK/XKR section to get the correct audience. A moderator may move this post there.
Old Aug 31, 2015 | 03:05 PM
24ktairman's Avatar
Out of warranty - but I think I can make this work . Thanks to your download. Thanks again
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
