trouble code 37
Old Jul 8, 2013 | 07:10 PM
AndrewDawson's Avatar
Smile trouble code 37
new member here with a 93xj6 vdp,code 37 in ecu. i have 12volts at egr vacuum solenoid and 12volts at ecu on the return side of egr vacuum solenoid.bench testing vacuum solenoid with 12volts reveals audible click when triggered. is it possible that egr itself can trigger this code? vacuum is present while engine running at egr. with little else left except ecu fault, is this a common fault on this car or should i keep on going with diag.
Old Jul 8, 2013 | 09:17 PM
motorcarman's Avatar
The ECM detects the EGR solenoid coil winding and if the resistance/current draw is out of spec, the DTC 37 is flagged.
I uploaded the S91_AJ6 4.0 Engine Management.pdf and it will have ALL the info you need to diagnose.
A word of experience to you is that I once had a 1991 XJ40 with a HARD FAULT DTC 37. It turned out that the power transistor in the ECM for the EGR vacuum solenoid failed and the code was PERMANENT!!!!!!!!
I swapped the ECM to another car and the fault FOLLOWED.
Download the guide and diagnose!!!!!
bob gauff
Old Jul 29, 2013 | 09:39 AM
dogpak's Avatar
Default Where do I find your upload?
Where do I find this upload? Seems like it could be quite useful...if I could find it!
Old Jul 29, 2013 | 10:51 AM
It's in the XJ40 FAQ's. Follow this link:
http://www.mediafire.com/?szzac3ieidammq9
This will take you to the forum MediaFire account where you can view or download the doc. Note that it's 13.4MB if you have a slow internet connection.
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
skyryder
Mar 25, 2016 08:18 PM
Poet
Oct 6, 2015 09:40 PM
jagfool
Sep 14, 2015 07:50 PM
