trunk lid
Old Apr 26, 2009 | 05:32 PM
kats98's Avatar
Default trunk lid
911-negative termanle of battery is disconnected. trunkk lid is closed. all electrical is down. how do i open the trunk lid? please responde 911
Old Apr 26, 2009 | 06:02 PM
hlgeorge's Avatar
You should be able to use your key to manually open it. What model car is it?
Old Apr 26, 2009 | 07:15 PM
Thermo's Avatar
Veteran: Navy
Kats, if you don't have a key hole in the trunk, what you can do is to get a spare power source (second battery, neighbors car, etc) and then access the engine bay. From here, what you will need to do is to get a set of jumper cables and connect them such that the negative battery cable gets connected to the block of the motor and then you should have a jump post under the hood. Connect the positive of the jumper cables there. At this point, you should be able to open the trunk as the car will have power via your spare source.
magmedia
Aug 15, 2019 08:54 PM
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
