want to change shocks to standard
Old May 19, 2011 | 02:50 PM
xjrguy's Avatar
Originally Posted by slorider
I need any advice on changing existing shocks, to standard verison and what would be the best kind to use. I have a 1991 sovereign ihate the way it rides, also any tips on why it sometimes pull hard right or left when you put on brakes. any help will be greatly appreciated.
Jaguar used to offer a change-over kit to delete the ride-leveling. It was part number JLM11698. They don't have it any more, but I'm sure if you Google the part number you can find someone that makes them up.
For the brakes, you probably need the ABS valve block. It was made available separately after those cars were out of production. The bulletin is attached.
Good luck!
File Type: pdf
Wolfy
May 28, 2024 08:06 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
OkieTim
Sep 8, 2015 04:48 PM
EZDriver
Sep 8, 2015 09:25 AM
Busa R
Sep 3, 2015 05:01 PM
