Windscreen washer issue
Old Mar 7, 2024 | 04:08 AM
jj12591's Avatar
Default Windscreen washer issue
Hi all , noticed my windscreen washer will only work once when the car or battery is first turned on , after that no matter how many times I push the button the motor is not engaging or making any noise , though the wipers will still kick in... I have already replaced the pump and fired air threw the nozzles, any ideas ? , thankyou
Old Mar 7, 2024 | 05:12 AM
jerry_hoback's Avatar
If you unplug the pump and "Hotwire" it, will it work then? If so I suggest there's a bad relay somewhere?
Old Mar 7, 2024 | 05:19 AM
jj12591's Avatar
Humour me , what are you suggesting by hotwire?
Old Mar 7, 2024 | 05:30 AM
Welcome to the forums jj12591,
I'll take a wild guess it's a Jaguar as the only information in your profile is your Country of Residence is GB:
Old Mar 7, 2024 | 09:05 AM
Run a wire directly from the battery to the pump and if it isn't grounded by its mounting, a wire to ground. If the pump is good, it should work that way
Old Mar 7, 2024 | 09:38 AM
jj12591's Avatar
I'll attempt it when I have time , but it's a new pump I've just put on , so can't see the actual pump being an issue
1sloXJR
Jul 19, 2022 01:16 PM
drbill
Mar 9, 2022 02:30 PM
chillyp
Jan 1, 2021 12:11 PM
billm
Sep 9, 2012 10:35 AM
