Windshield Washer flow
Old Dec 30, 2020 | 11:52 AM
chillyp's Avatar
Default Windshield Washer flow
Hello,
I do not have a "washer fluid low" message on my dash and the wipers operate, however I do not have any fluid coming out. My guess is either the motor in the wheel well has stop working or the nozzles are clogged up. I figured since the car is sitting in the garage for the next few months I'd try to fix this. Any links (video or pages) on how I should go about spending my time trying to fix this?
Old Dec 31, 2020 | 07:52 AM
dfbender's Avatar
Originally Posted by chillyp
Hello,
I have the same issue so I’ll be watching the replays.
Old Dec 31, 2020 | 08:15 AM
Here's a relevant thread covering the pump and washer nozzles:
https://www.jaguarforums.com/forum/x...t-work-198086/
Old Dec 31, 2020 | 05:11 PM
chillyp's Avatar
Thank you.
Old Jan 1, 2021 | 12:11 PM
bcprice36's Avatar
Hey chillyp & dfbender,
Hey Guys, In order to fix your problem, you need to get down to the Water storage Bottle and make sure the little pump motors are working and that all your hoses are connected and that you still have water in the Bottle. Problem: You've got to raise the Left Front and remove the Wheel well shield, so you can see the storage Bottle...Also, some X-100's have Headlight Washers and some don't....but if you want to make sure on a 20 year old Car, you are going to have to go down there and look.... Best place for parts? The Junk Yard.....
Billy Clyde @ Cinco Ranch
1sloXJR
Jul 19, 2022 01:16 PM
Rickkk
Mar 10, 2022 08:22 AM
DuhCar
Jan 8, 2016 07:32 AM
Striker27
Oct 14, 2007 05:04 AM
