Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Sponsored by: CARiD
Wood Care
Old Jul 3, 2009 | 07:21 AM
FloridaJag's Avatar
Default Wood Care
I checked the owners manual on my 2003 S-type. It does not explain how to clean the wood. I would expect to use a damp cloth with a mild soap. Is that correct?
Old Jul 4, 2009 | 05:08 PM
hlgeorge's Avatar
I used a good auto glass cleaner (without ammonia). Then put a coat of NXT sealant on it. Looks beautiful!!
Old Jul 14, 2009 | 12:27 AM
steves1986's Avatar
Good to use, really looking beautiful.
Old Jul 16, 2009 | 11:05 PM
93xj6's Avatar
Probably different on the newer cars But I've used pledge on some of my wood before in the 93
Old Aug 23, 2009 | 10:35 PM
2004x-type's Avatar
I use Pledge. Works really great, just make sure to get all of it off. I hate streaks! lol
Old Aug 24, 2009 | 03:24 PM
hlgeorge's Avatar
The Pledge will clean it and make it shine for a while, but it is only a temporary "oily" shine. The urethane coating on the wood of the newer cars is a very hard surface and doesn't absorb anything. It is best to use the polymer waxes as they also have a UV blocking agent in them also, especially helping the drop top cars. Have you seen the milky urethane over the wood on some convertables? Results of UV light!
Old Dec 14, 2009 | 06:28 PM
Jag Po''s Avatar
Don't use Pledge for ANYTHING -- it will actually harm the finish.
Best product I've found is Scott's Liquid Gold.
--Apply it liberally and thoroughly -- use Q-tips to get in all the corners and hard to get to places. Rub it in good.
-- Allow to soak in about an hour
-- Wipe off excess then buff with soft dry cloth. It will look like NEW!
Old Dec 17, 2009 | 02:19 PM
2004x-type's Avatar
Where should I get the polymer wax? Also, what would be the best way to repair the finish on the wood? On my XJR, there are 2 cracks in the finish, not the wood, and I would LOVE to fix that. Also, on the passanger door, there are lots of little dots in the finish, I'm assuming from the seatbelt hitting it or something, how should I get that out?
Old Dec 18, 2009 | 09:24 AM
m0t0rm0uth's Avatar
polymer wax can be had at almost any auto parts store.
For the cracks, not much you can do, if the crack is all the way through the coating to the wood. You can try to repair it by using some new polyurethane, but I can't guarantee that it will fill the crack.
As for the "dots in the finish," you can use some FINE grit sandpaper (about 2000 grit) to sand the top layer of urethane, and then put some more on. IF YOU DO THIS, take the panel off the car first (I know...it sounds dumb to have to mention that, but you'd be surprised), wet-sand it lightly, and, before you respray the urethane, make absolutely sure there isn't any dust or other particles floating around in the air. If there is, you're going to be VERY upset...lol.
Old Dec 18, 2009 | 12:11 PM
Stimpy's Avatar
I have an 06 Xtype. Is it really even wood... it looks like plastic.
Old Dec 18, 2009 | 11:09 PM
m0t0rm0uth's Avatar
Yes, it's wood. It has a very thick polyurethane coating that makes it appear plastic. That covering protects the wood from UV rays, moisture, etc.
The wood (at least on the 70's models) is a veneer, and almost typically isn't solid.
robbing
Mar 5, 2024 10:51 AM
bdboyle
Sep 16, 2019 05:58 PM
Johnken
Oct 2, 2015 10:12 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
