Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Alternative trensmission behind V8 engine?
Old Jun 19, 2011 | 10:39 AM
XJS3.6's Avatar
Default Alternative trensmission behind V8 engine?
as in topic, do anyone have any suggestions for retro fitting an XJR engine in a older car?
Engine will be running with an aftermarket ECU, but I hoped to use a automatic transmission behind it.
so is it any ways to make a automatic fit and work behind the V8?
Make an adapter plate for TH400 from the V12 engine?
what kind of transmissions was offerd for the V8 actually?
thanks for any help.
-Ole-
Old Jun 19, 2011 | 01:14 PM
MidlifeXJR's Avatar
I can't say on the retrofit issue, but as I have just become intimate with the transmission in mine as it blew up, the Mercedes 722.6 (W5A-580) is the one that is in it. There were very few options for heavy duty transmissions for the HP/Torque of these motors. It is electronic and the gearshift as well as the TCM are specific to it.
Old Jun 19, 2011 | 05:10 PM
XJS3.6's Avatar
I've heard that the mercedes transmissions in the XJR was not good.
The TH400 is said to be a good transmission that can survive the most, but, I've noticed that the mounting flange looks similar on the V12 trans V.S V8 Trans.
Old Jun 19, 2011 | 05:20 PM
motorcarman's Avatar
If I were thinking about this, I would consider the 700R4. They can be made to withstand a bunch of torque. They are plentiful here in the U.S. and no TCM needed (just a cable to the throttle). You would have the overdrive that the T400 does not have. The THM400 is a bulletproof gearbox and I just built one to put in my supercharged small block Chevy powered car. I installed the TransGo 123 so it should be OK.
bob gauff
Old Jun 22, 2011 | 04:55 PM
XJS3.6's Avatar
thanks for the tip
I think that is a better option because of the missing overdrive on the 400.
Old Jun 22, 2011 | 05:06 PM
plums's Avatar
Originally Posted by XJS3.6
Engine will be running with an aftermarket ECU ...
Any further information on the ECU?
Old Jun 25, 2011 | 01:46 PM
XJS3.6's Avatar
It will eather be MSIII or Autronic
mrplow58
Jan 21, 2024 05:53 AM
3lvis
Oct 1, 2015 01:56 PM
Dicque
Sep 19, 2015 12:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
