Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Cam Timing Tool for AJ27S...
Old Jul 6, 2011 | 09:30 PM
SprintStar's Avatar
Default Cam Timing Tool for AJ27S...
Is a cam timing tool necessary when changing head gasket for a 2002 Supercharged V8?
The car is a RHD Daimler Super V8. First and last cylinder on passenger side (left of car) no compression. Plastic water hose clip broke and car overheated...
Thanks for any help.
Sprint.
Old Jul 8, 2011 | 07:18 PM
Count Iblis's Avatar
I don't have a answer to your question but if it overheated badly and has a plastic impeller waterpump- the chances are that the pump is melted and will need changing too. I've seen this many times. The AJV8 has minimal volume "precision cooling"-which is designed for rapid warm up. This it does well, compared to other engines of similar power- howere the down side is there is less reserve in the cooling system
Old Jul 18, 2011 | 05:40 AM
SprintStar's Avatar
Dear all,
I found out what was causing the problem. Dropped valve seats. How do I remedy this? New cylinder head or may I install new seats in the old heads?
Anyone has heads for sale? Left bank. Passenger side in a RHD car.
Thanks!
Sprint.
Wolfy
May 28, 2024 08:06 AM
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
Sprayall
Sep 3, 2015 07:49 PM
