Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Kenny Bell Upgrade among other Things
Old Nov 16, 2015 | 11:48 PM
avos's Avatar
500 at the hub for a 3"pulley is in the ballpark you can expect. Here is another hub dyno result for a 4.2 XJR, with a DBX85/82mm TB, but bigger 4.2 lower pulley (assuming you have still the 4.0 one?)
https://www.jaguarforums.com/forum/p...6/#post1213836
Old Jul 17, 2016 | 11:32 AM
Addicted2boost's Avatar
Amiddlecott,
Do you have any further updates on your car and any possible solutions to your MAF sensor placement?
Old Jul 18, 2016 | 04:26 AM
amiddlecott's Avatar
This upgrade has been a long and expensive mission... I have had fitted a new ECU which can cope with the additional power, the MAP on the original one was not capable of managing the fuel air ....etc
A long update is coming but have to wait till i take a holiday to get the time to do it..
The MAF was fitted in the bumper, I think the same place AVOS fitted his. Difficult to get to if you want to mod unless you fit a extended USB port lead.
not sure if this helps you.
Old Jul 18, 2016 | 07:29 PM
dc4prez's Avatar
I've had the same troubles - Abaco appear to have gone broke - No problem to me - I use a MAP and leave the (Abaco Junk) MAF wired to the Jag computer - (same with original injector and coil wiring, shorted out with resistors) -
My ECU is Infinity - The engineer has emailed me a week ago, saying they are only a few months away from releasing a full kit = THROW THE JAG ECU AWAY, which will run all of the Original Jag ECU operations plus be fully programmable
Old Jul 21, 2016 | 02:05 PM
ronbros's Avatar
there yah go about time, standalone ECU, seems MAP systems are more tunable anyway, i have seen MAF meters cuase problems when located improperly(eddy air waves).
Forcedair1
Sep 8, 2025 01:57 PM
trosty
26
Dec 18, 2022 06:40 PM
abonano
25
Sep 25, 2015 10:43 AM
timm525
Sep 8, 2015 07:57 PM
Mike Green
Sep 7, 2015 12:39 AM
