Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
STR cold air intake?
Old Nov 30, 2010 | 06:39 AM
gregstar's Avatar
Default STR cold air intake?
Hi all,
I'm looking for a good cold air intake for my s type R. No one in the UK seems to do str stuff. I tried a mins gallery induction kit ( normal) and it seemed to
Choke the car.
Can any one point me in the direction of a manufacturer? Or should I diy!
Old Nov 30, 2010 | 09:05 AM
motorcarman's Avatar
You already have a cold air intake if you have the factory air cleaner.
bob gauff
Old Nov 30, 2010 | 09:15 AM
gregstar's Avatar
So just change the panel filter to a higher flow one?
Old Dec 2, 2010 | 09:57 PM
The airbox draws air from outside the engine compartment. I would say 'that is a cold air intake'. If you use one of the oil wetted filter elements, I have read posts that state not to use too much oil as the MAFS might get coated/contaminated with excess oil film and provide a false reading to the ECM. I don't know the flow rate of the different air filter elements so I don't know if the paper is a limiting factor in airflow. There are lots of posts on this subject with alot of opinions from 'Stock' to 'K and N' types. Do search and decide for yourself!!
bob gauff
Old Dec 27, 2010 | 08:34 AM
steve11's Avatar
ud
I no longer put dogs in these fights. Performance of aftermarket air intake systems have dual influences coming from preception and reality. Whichever one satisfies you that you've got your money's worth is money well spent....and it's darned good for the economy too.
Old Dec 27, 2010 | 09:44 AM
Mikey's Avatar
The factory air filter is already a high flow type.
Old Dec 27, 2010 | 10:24 AM
avos's Avatar
You already have a cold air filter system as steve11 mentioned, so only thing left is a K&N filter. It does flow more, that’s not the question, and the differences become even bigger once the original paper filter becomes dirty. Just don't overoil the filter. Also, don’t expect any noticeable power increase, it will only give a little, but still if you after power all bits help.
Old Dec 27, 2010 | 12:18 PM
Brutal's Avatar
youde be far ahead to sell the stype r and get a xkr, and upgrade to a AVOS twin screw
Old Jan 16, 2011 | 01:51 PM
Riski's Avatar
bump
02jagstype
23
Oct 23, 2022 07:03 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
explorer364
Sep 11, 2015 05:44 PM
tonyforman
Sep 10, 2015 07:23 PM
1100me
Sep 7, 2015 06:26 AM
