Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Tea leaf reading anyone- how about these spark plugs ?
Old Jan 20, 2012 | 07:37 PM
Newby's Avatar
Default Tea leaf reading anyone- how about these spark plugs ?
I removed what I think are the original plugs today (37K miles on a 2002 XJ8) and I found a small amount of oil on the threads of 2 of the plugs. As I peered wayyyyy down into the head I could see just a few drops of fresh clean oil.
I'm assuming this means that there is a small valve cover gasket leak...yes?
The plugs I removed were NGK [U]R [U] PFR50 11E and were gapped at .040 Are these likely factory originals??
I replaced them with NGK Iridium IX BKREIX-11 stock # 5464 gapped to .035, drove the car to test and it ran flawlessly, so I didn't mess anything up
I'm attaching a photo of the plugs-what do these tell you?
Thank you in advance for all your help
Attached Thumbnails Tea leaf reading anyone- how about these spark plugs ?-jag-original-plugs-37k.jpg
Old Jan 20, 2012 | 08:28 PM
motorcarman's Avatar
The factory plugs are to be replaced at 100K miles in the NA 4.0 engine.
The originals are the NGK plugs you removed.
bob gauff
Old Jan 20, 2012 | 08:55 PM
Newby's Avatar
bob gauff
Thank you for your fast help on this and my other "what is this part" post.
I thought I would change the plugs since the plugs were in the car 10 years. I was also curious to find out if they would be easy to remove, which they were.
So I should be able to go 100K miles on this set of iridium plugs then?
Old Jan 21, 2012 | 09:04 PM
You probably could have gone 60K more miles on the originals.
I replaced my 1999 XJ8L plugs with Jaguar OEM (I get wholesale price from the dealer)
at 97K miles when I replaced all the timing chains/tensioners.
I don't know about the Iridium plugs because I never tried them.
bob gauff
Old Jan 22, 2012 | 03:34 PM
Fraser Mitchell's Avatar
Yes !
Oil leakage into the plug recesses is commonplace on many DOHC engines where the plugs go down tunnels formed by the cam cover and cambox. Normally a new cam cover gasket solves the problem.
Old Jan 22, 2012 | 05:52 PM
Newby's Avatar
Yes !
Where should I buy these from? I live in the San Francisco Bay area.
thank you
cissdm
May 3, 2016 06:02 AM
joesoap
Sep 10, 2015 01:09 AM
mrplow58
Sep 9, 2015 11:27 AM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
