Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Auto Transmission
Old May 23, 2021 | 11:45 AM
Matthelm's Avatar
Default Auto Transmission
Driving along the M3 had transmission fault come on so i stopped and called the AA who when they arrived hooked up the diagnostic reader checked both the engine and Gearbox and only found data faults which they promptly re set and said it was fine to continue my journey to the Midlands while I was on the M1 the Fault came on again there is no loss of performance from engine or Transmission any ideas as to what it might be vehicle is 2011 3.0d
Old May 23, 2021 | 05:12 PM
Originally Posted by Matthelm
..... only found data faults which they promptly re set and said it was fine to continue my journey to the Midlands while I was on the M1 the Fault came on again .....
Welcome to the forums Matthelm,
As it states at the top ....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS. Please answer the questions below and I'll move it to the relevant model forum.
When the AA cleared the codes, the transmission fault warning would have cleared BUT it came back again after a couple of cycles because they didn't fix the cause of the fault.
1. please advise model
2. did they tell you the codes?
Rebbecca
Mar 19, 2026 07:54 AM
Salim1luv
May 11, 2021 12:16 AM
Chantel Clayton
Sep 27, 2020 05:38 PM
ROGERP
Jan 25, 2012 06:04 AM
