Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Cannot post using IE 11 = Windows 8.1
Old Dec 31, 2013 | 10:39 AM
Roger Mabry's Avatar
Default Cannot post using IE 11 = Windows 8.1
I have to switch to Chrome to post on this Forum. Using IE 11, it says the message is "too short"....needs to be updated for use with current IE.
Old Dec 31, 2013 | 11:48 AM
Cadillac's Avatar
I assumed you would be fine with Win 8 and IE11 . I use Opera with these forums and works very well
Old Dec 31, 2013 | 12:43 PM
avt007's Avatar
I was forced to chnage to Chrome as well, since the URL popup window doesn't work in IE11 for me.
Old Dec 31, 2013 | 01:25 PM
plums's Avatar
seeing as every Windows computer sold this holiday season likely came with IE11/Win8.1 ... some work is ahead
Old Jan 31, 2014 | 11:30 AM
littlelic69's Avatar
I too have had problems posting on this forum using Windows8. It disabled my router/computer connection! Am about to try again! This time it worked!!
Old Feb 18, 2014 | 10:59 AM
AJ34S's Avatar
MIne just refuses to post, each time I try it says I must enter some text and deletes my message....most annoying...but as said here maybe only for IE11....as usual it is a Windows/IE "feature" something to do with the scripts I believe, although Microsoft are blaming the forums for not supporting it......so business as usual all thank God that Bill and his crew doidn't supply the software for Jaguar!
Old Feb 18, 2014 | 11:55 AM
Schwabe's Avatar
I have no problems with 8.1 and IE11. Maybe enable "compatibility mode" and add the site url to safe sites. If you just chose "recommended" settings when you launch IE for the first time it may be locked down too much.
Old Mar 2, 2014 | 04:34 PM
Marsden's Avatar
Having a similar problem with Win7 and FF27.
Just lately it's been happening that the system logs me out when I hit 'submit reply' ... I have to try to remember to copy my text before posting, else it's lost. This happens erratically but often enough that it's a real nuisance. Just a data point.
Might be a javascript thing, though I keep my eye on those. Hmm.
Old Mar 2, 2014 | 04:44 PM
Marsden's Avatar
It just happened again, with another long post which I forgot to copy before hitting "submit reply"... system logged me out and lost the text.
Giving up for now
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
