Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Post New Thread Button
Old Sep 12, 2013 | 01:23 PM
Default Post New Thread Button
Hi All, as I'm sure most / some of you may be aware we have now changed the buttons in the section from "New thread" to "post new thread".
Its a slightly newer look and may help to alleviate any issues moving forward, helping to make the site more user firendly.
Thank you
Old Sep 12, 2013 | 02:00 PM
Errr, maybe not quite yet.
But this is what is going to happen.
It should help with navigation.
(PS moved into a new thread).
Old Sep 12, 2013 | 02:57 PM
plums's Avatar
Ummm...
"post new thread" contains two words that might be somewhat meaningless to internet or forum novices. post? thread?
However, "start new topic" might have the desired effect as it mirrors the thought of the member when he scans(hopefully) the page looking for some indication that satisfies his desire to start a new topic.
Old Sep 12, 2013 | 06:45 PM
Point taken Plums, but its a change for the better, a slight upgrade if you will to the existing, hopefully to help newbies out some.
Its not a totally new change, therefore keeping a little of what once was, not always a bad thing.
We were all new here at some point, new to many different things at some point. Its what you put in that mirrors what you get out, and it will take a little checking around & a little research combined with common sense to get the gist of anything.
The new style button doesn't seem to be showing as yet for some reason, looking into it.
Old Sep 13, 2013 | 02:15 AM
plums's Avatar
If it's supposed to be available then clear your local cache, or hit ctrl+f5 while on a page where the old button is showing. Any of the topic index pages will do the trick.
The above actions will force the browser to grab a fresh copy of the same file name.
Old Sep 13, 2013 | 05:57 AM
Its showing for me, it just seems that others may have an issue seeing it?
Please post here if you can or can't see it.
Old Sep 13, 2013 | 07:43 AM
It wasn't for me but Plums ctrl+f5 tip did the trick
Old Sep 13, 2013 | 09:32 AM
Typically it is me that has the problem.
After clearing and refreshing see below.
Not to worry, I don't really need to see it.
Old Sep 24, 2014 | 06:36 PM
Drinkwine47's Avatar
Default Post new thread/question
Where and how do i post a new thread/question
chris p
Old Sep 25, 2014 | 12:00 AM
chris p
Chris,
When you enter a section, just above the list of topics for that section, on the upper left, is a dark gray button labeled in white, "Post New Thread."
Click on that and a new blank compose box appears.
Old Sep 25, 2014 | 02:41 AM
The Post New Thread button is available from any main forum but NOT from within a thread:
clubairth1
30
Sep 3, 2025 04:38 PM
JarodL
Mar 7, 2024 01:39 AM
Rivguy
Dec 4, 2020 07:55 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Doovoe
Sep 8, 2015 05:42 PM
