Mark V - X 420G 1948 - 1970
1958 Mark VIII
Old Jul 14, 2014 | 09:20 PM
  #41
RedDog's Avatar
Mike,
Where you able to find any retainer clips for the rimbellishers or did you use the hose clamp trick? If so, mind sharing.
Also, beautiful job with the restoration.
Old Jul 16, 2014 | 12:11 PM
  #42
Rotomike's Avatar
Hello,
I was not able to find a source for the retainer clips. I tried the hose clamp trick but discovered that the clips interfere with the brake drum. I spent a long time getting the clips all set inside the wheel and adjusted to hold the trim, but when I went to put the wheel on the car they jammed up on the brake drum. This method would only work with disk brakes I believe. I ended up getting modern chrome rings that fit the car.
mike
Old Jul 16, 2014 | 02:31 PM
  #43
RedDog's Avatar
Thank you for the follow up and glad you found a solution. I have been using the hose clamp method on my MKIX for the wheels that are missing the original clamps but I would love to replace them with the correct piece.
Old Feb 11, 2021 | 10:42 AM
  #44
Rotomike's Avatar
Default Embellisher clips
Hi RedDog,
Its been a long time but I thought I would do a followup on these clips. My solution of using aftermarket rims didn't last. This past summer one of them took its own trip and and the following truck made mince meat out of it. So I decided to try to make my own clips. I still had a couple so I used them as my template. I got some 18 gauge steel and cut it into strips. Found some 1/8" brass rod, drilled it and tapped some threads. I used 8-32 screws. Just bent the pieces in the vice to shape and trimmed with a tin snips. I had the correct trim rings in storage when I first started working on the car and hung onto them in case I ever got to this point. Tried them on and the clips worked great.
For some reason I didn't have the patience 7 yrs ago to do this, but I'm glad I got it done. Hope you can use this info. Mike
Bent the steel strap over brass rod for shape. Then cut the slot.Brass rod cut to length, drilled and tapped.
A couple of these are original Can you tell which ones?
Outside of wheel
Inside of wheel
There is low tension on the clips, and they hold fine.
Old Jul 29, 2024 | 11:53 AM
  #45
ajmoss2006's Avatar
Default My 1958 jaguar
I was wondering where can I find parts in I need a distributor cap and wires? Or is there a conversion I could use like a hei? Or can a small block 350 and tranny be transplanted without cutting?
Old Jul 29, 2024 | 11:58 AM
  #46
ajmoss2006's Avatar
Originally Posted by Rotomike
The club has about 100 members that pay an annual membership fee of $20.
Storing your car at the club gives you unlimited access to the building and the use of the facilities. The building will handle about 35 cars. Annual storage fee is $650.00 a year per vehicle.
mike
where is this located?????
Old Jul 29, 2024 | 11:59 AM
  #47
ajmoss2006's Avatar
I wanted to find a car that was as old as me, so if I couldn't reclaim my youth at least I could help my car to.
The pics show the progression. Body off, frame cleaned up and powder coated, suspension and running gear going back on.
I've lined up the body to be soda blasted so the body work can be started.
mike
1958 Mark VIII
I'm in need of some parts or advice???
Old Jul 30, 2024 | 07:17 AM
  #48
Rotomike's Avatar
try Moss Motors. They should have a catalog for parts for you
Old Jul 30, 2024 | 07:46 AM
  #49
Rotomike's Avatar
oshkosh, wi
Old Jul 30, 2024 | 07:59 AM
  #50
Rotomike's Avatar
Or try Worchester Classic Spares, located in England
Duke85
Jun 14, 2020 11:53 AM
Grif
UK & Eire
Sep 11, 2016 10:30 AM
HistoryBuff
XKSS
Jul 28, 2013 06:06 PM
Fla Steve
Mar 25, 2011 05:40 PM
