Mark V - X 420G 1948 - 1970
1964 Mark X -Electrical Polarity?
Old Aug 13, 2020 | 03:57 PM
Regul8R's Avatar
Default 1964 Mark X -Electrical Polarity?
I have a 1964 Mark X 3.8.
I've never worked on this type of car before.
I've heard the polarity is different on these cars, is that accurate?
If so, can it be changed to negative ground?
If changed to negative ground, does absolutely everything need to be changed out of the car- like power windows and such?
The car is getting a Chevy 350 motor.
Old Aug 13, 2020 | 05:55 PM
Fraser Mitchell's Avatar
I had a 1967 Mark 2 swapped to negative earth by an autoelectrician. It was almost a five minute job, but you have to swap over the leads on the ammeter so slightly more time.
Old Aug 16, 2020 | 04:08 PM
S-Type Owner's Avatar
Also, if your car is equipped with a radio, it too will have to be switched over to negative ground, or bad thinks can happen...
Old Aug 17, 2020 | 08:39 AM
Bob_S's Avatar
Hi Rugul8r,
Here is a procedure for switching from positive to negative ground. It came from the JCNA web site it covers the basics.
https://www.jcna.com/positive-negati...d-conversion-0
For the power window I would try it without swapping the leads, it should work. But the switches may work backwards.
Sorry to hear about the 350 swap, that's a lot more involved than a simple polarity change. But if that keeps/gets the car back on the road so people can enjoy it, so be it.
I had a friend who wanted to swap a Jaguar 6 cylinder engine in to a 36 Chevy just to prove a point. He never got around to it, RIP Gary, you're missed.
84jagxjs
Jun 14, 2019 01:32 AM
egovreau
XK120 XK140 XK150
Nov 21, 2018 08:46 PM
Some Day, Some Day
Sep 11, 2016 02:35 PM
OWRltd
Mar 30, 2012 04:13 PM
oilman151
Sep 30, 2008 12:24 PM
