Mark V - X 420G 1948 - 1970
MK V 3.5 engine tuning
Old Jul 2, 2020 | 12:51 PM
dirkroels59's Avatar
Default MK V 3.5 engine tuning
Hi there,
After having finished my engine revision, I'm still strugling with the tuning of my engine.
I can have it running well at idle, but as soon as I try to accelerate it, it start stottering and back firing. Often the engine stall's at that moment.
I checked the ignition timing, and I see that this is wandering around with about 5° around the timing mark. Dough I have an electronic ignition installed...
I disconnected the automatic choke actuator, but this doesn't change a thing.
Anyone an idea what could be the cause of this?
Thanks for your advise.
Dirk
Old Jul 3, 2020 | 05:30 AM
Fraser Mitchell's Avatar
Normally those symptoms are related to fuel supply - runs OK at idle when not much fuel is needed. but when accelerating not enough fuel is being supplied. Have you checked this aspect out ?
Old Jul 3, 2020 | 12:27 PM
Bob_S's Avatar
Hi Dirk,
If the ignition timing is wondering 5 degrees (which is a lot), I would say you have a worn distributor or distributor drive gears. The timing should not be moving around much.
Old Jul 12, 2020 | 12:51 PM
Hi Fraser,
I excluded the idea of having a short of fuel as I have also backfire in the exhaust.
I don't think that it can be the cause.
Dirk
Old Jul 12, 2020 | 12:52 PM
Hi Bob,
I have sent my distributor in for reconditioning, hoping this will help.
thanks
Dirk
type2guy
Jun 19, 2020 03:29 PM
ivanhoew
XJ40 ( XJ81 )
Jan 12, 2019 02:40 PM
yachtmanbuttson
Jul 1, 2018 06:17 AM
Homersimpson
Mar 24, 2018 04:29 AM
NJ2003XJ8
Apr 12, 2016 05:12 PM
