Mark V - X 420G 1948 - 1970
Mk8 Resto Wheels
Old Apr 12, 2022 | 07:01 PM
DB48's Avatar
Default Mk8 Resto Wheels
Wondering if anyone has put Jaguar wire/spoke wheels on Mk8 or Mk9. Or spacers. In NZ legally spacers max at 37mm. I see there might need to be minor body work where the body tucks in at the front of rear guards.
are the wire wheels similar size to Mk8 wheels. I realise also wires have knock on hubs. Likely simplest solution to get a better looking “stance” would be custom spacers.
Old Apr 14, 2022 | 10:49 PM
Bill Mac's Avatar
You could also investigate bolt on wire wheels.
These use the existing wheel studs.
In Australia there were 15 inch bolt on wires which had a GM pattern spacing which was the same as the MK1 and MK2 bolt pattern.
I don't know if 16 inch bolt ons are available for the MK7/8/9
It is worth investigating as it is a far cheaper way than going down the knock off hub system.
CaptnCarl
E type ( XK-E )
Apr 23, 2023 05:38 AM
Terrance39
Aug 22, 2021 01:50 PM
powerhouse
Jan 1, 2018 04:23 PM
srjag
Oct 31, 2009 11:11 AM
