1966 Jaguar 3.4 S Type Wiper Motors
Dears,
Has anyone upgraded their wiper motors on a Mk2 or S Type ? If so some useful pointers/info would be greatly appreciated.
Many thanks for any feedback - Derek
Have a look at Wiper System Upgrade ? Valve Chatter Lin upgraded his, he will have all the info there as he has so well documented everything he did.
Hi Jose,
The only reason being I need to reülace because the fast speed no longer works and was just wondering if there was something somewhat better than buying a straight replacement.
I see.
Have you checked the Switch at the steering column?
Have you checked the carbon bushes at the motor?
you might ask the question at the S Type Register forum, where there are more S type owners who might offer suggestions.
International S type Register:
www.jagstyperegister.com
Littlejonah
The DR3 wiper motor has a resistance wire wrapped around the field winding, these can get burnt out and the fast speed will not work.
If you have a read of this you may be able to check where the fault lies, it could be the switch, the resistance wire or a bad connection, it wont be the brushes unless the slow speed does not work either. https://www.thorden.dk/Teknik/two-speed.pdf
See how you get on
See how you get on
Fidanza
Oct 21, 2008 09:45 AM
