1967 420 restoration
Old Oct 13, 2023 | 06:50 PM
  #201
Glyn M Ruck's Avatar
Agreed. The handsome 420 is an ignored model that fetches poor prices. This will change & I would grab one while they are cheap if you have space for it.
Old Oct 14, 2023 | 08:02 AM
  #202
Peter3442's Avatar
The front subframe, steering, suspension that I recently bought are from an abandoned 420 project. The body looked good (from a distance). Hopefully, someone will use it and the other pieces to complete a 420. Still, transplantation into a Mk2 is better than going to scrap metal.
Old Apr 12, 2025 | 02:08 AM
  #203
Rens's Avatar
Smile PDF handleiding 420
Goedemorgen, ik zou graag een PDF handleiding van een 420 willen ontvangen
Groetend Rens
Originally Posted by Cass3958
Compression should be about 160 psi plus so keep pouring the seafoam in to the cylinders.
The vinyl is called Ambla and to be truthful although it was supposed to be a cheap alternative to leather fitted by Jaguar to save some money, (leather was an option but cost more) if you had a leather interior you would be throwing it away now. Judging by the condition of the car it does look as though it has been sat for a time and the leather untreated would have dried up and cracked by now. I have black Ambla in my S type and it still looks new 54 years on.
It took me 18 months (by myself) from purchase to back on the road with my S type but I took it back to bare metal and removed every nut and bolt, everything was cleaned, polished, refurbished and if needed bought new. I think a year to get a good running and driving car is doable but with all these things other things get in the way. Do not set a target date but if you do, say a year then add 9 months as a contingency. Same with the money budget. Either do not set a budget or if you do set a number and then double it plus add another 50% as a contingency. I thought I was done and then found I had to have the gearbox rebuilt as the car was not running when I bought it and I wrongly assumed the gearbox was OK.
Although there are not many 420s on this forum the 420 shared a lot of parts with the Mk2 and the S Type and there is a wealth of knowledge on this forum that you can tap into so don't be afraid of asking questions because we love to answer them. If you want a 420 service manual on a PDF file send me a PM with your e mail and I will send one to you as a present.
Old Apr 14, 2025 | 02:56 AM
  #204
Cass3958's Avatar
Groetend Rens
Send me a PM with your email address and I will send a copy over to you or you can down load a copy from here.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.jagstyperegister.com/images/maintdocs/servicemanual420.pdf
Old Apr 14, 2025 | 04:05 AM
  #205
Rens's Avatar
[QUOTE=Cass3958;2837597]Stuur me een PM met je e-mailadres en ik stuur je een kopie. Je kunt ook een kopie hier downloaden:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.jagstyperegister.com/images/maintdocs/servicemanual420.pdf[/QUOTE
Goedemorgen,
Hartelijk dank voor het mailen van de pdf die ik gelijk gedownload heb👍
gr
Rens
MrAndersonGCC
Apr 25, 2022 09:49 PM
lyonsfin
Oct 1, 2019 05:52 PM
Lambretta
16
Nov 21, 2018 08:01 PM
bendougy
Apr 21, 2015 04:47 PM
buddyluv
E type ( XK-E )
Feb 25, 2015 11:00 PM
