240 factory tires dims
Old Nov 9, 2018 | 06:23 AM
Lambretta's Avatar
Default 240 factory tires dims
Am i correct thinking that the 185/80R15 or the 185R15 are the closest today dims to the tires fitted from the factory?
Any recommendations?
Old Nov 9, 2018 | 07:33 AM
Glyn M Ruck's Avatar
Correct!
Recommend Michelin 185VR15 ZVS or 185HR15 XVS-P 93H or Dunlop VR SP Sport Aquajet 185R15. They look period correct & are very good tyres.
There are cheaper options from Vredestein, Blockley, Hankook etc but you get what you pay for IMHO.
Old Nov 9, 2018 | 12:05 PM
JeffR1's Avatar
There's this too and what have on my car.
They're only 180's, but the aspect ratio must be at 85 or 90%, they are very tall.
You see a lot of guys running 195's, which appear too wide (getting close to the rear fender skirt) and 205's and they look really too wide.
https://www.longstonetyres.co.uk/cla...helin-xas.html
https://www.longstonetyres.co.uk/cla.../mki-mkii.html
Old Nov 9, 2018 | 01:42 PM
S-Type Owner's Avatar
I see that Longstone is featuring the Pirelli Cinturatos. Hopefully they have made their rubber compound a bit more durable. Back in the 1960s, those Pirellis were known to wear out long before 20K miles had elapsed, if the any sort of spirited driving was involved.
If the car is primarily for show, I guess this is a non-issue.
Old Nov 9, 2018 | 03:58 PM
Does anybody know anything about these Universal Tyres? Are they any good?
They are a pretty close copy of the original Dunlops.
It should be noted that the original 185R15 tyres did not have an aspect ratio of 100. Their (unstated) aspect ratio was 78 ~ 80%. The Michelin XAS 180HR15 has an aspect ratio of 80.
https://lucasclassictires.com/185HR1...rt-579876L.htm
Old Nov 9, 2018 | 05:20 PM
I also can't stand tyres with huge branding on the sidewalls on classic cars. They might be the right size but look totally out of place on a classic IMHO.
Old Nov 9, 2018 | 05:57 PM
JeffR1's Avatar
I have no experience with them, but they look nice.
The tread may make more noise then you may expect though.
The guy at Longstone tires was comparing the Michelin XAS to the other 185's and the 180 Michelins were still a little taller, that's why I figured the aspect ratio was a bit more then 80%.
Old Nov 9, 2018 | 08:21 PM
No problem! Aspect ratio is affected by many things including inflation, speed of rotation etc. (in real life vs. static). The Longstone site & Michelin themselves consider those XAS 180 X 15's to be 80 aspect ratio. I guess we should consider the values as nominal. All I'm interested in is the rolling circumference mounted & inflated to keep the speedo relatively accurate.
Old Nov 10, 2018 | 04:41 PM
sov211's Avatar
I have these Universals (but with the narrow white band, same tread pattern) on my 1966 Mk 2. They are smooth, quiet, and handle well. I recommend them.
Old Nov 10, 2018 | 05:00 PM
sov211's Avatar
Here is a photo of my 1966 car with the Universals; the white band width is correct for the 1966 period; all Jaguars for Canada (and I believe the US) came from the factory with whitewall tires until and including the 1982 model year. The field clippings in the tread were optional.
Old Nov 10, 2018 | 05:06 PM
Thank you. They look very good & are decently priced. Available plain, narrow white wall & red wall.
Very nice car BTW!
Old Nov 10, 2018 | 08:00 PM
sov211's Avatar
Another view of the Universal tires with the Jaguar attached. Somehow I can never see enough of these cars. As is the case with most Jaguars, the design is simply "right" and age does not diminish its beauty in the least. I wish I could say the same for myself. This car has just 26,000 oiginal miles on it. Fun to drive in a 50-year-old way.
Old Nov 11, 2018 | 05:39 AM
She's in absolutely stunning condition for her age & only 26K miles ~ amazing!
Old Nov 11, 2018 | 08:48 PM
sov211's Avatar
This car had only 16,000 miles (all documented) on it when I got it 15 years ago. It had been used so infrequently that anything that could leak, did. And the paint was tired and scratched. So I took it off the road and did a complete restoration, engine and transmission out, all suspension rubbers replaced, new shocks, all fluids, belts, generator and starter and fan motor taken apart for inspection, found perfect, brake system redone completely except that the car is still on its original brake discs (in almost new condition), interior removed, body taken to bare metal and refinished by Coachwerks here in Victoria (more than 300 hours logged).
The interior is almost completely original; I replaced the headliner because of soiling but the rest is reconditioned but as it was. The air conditioning is the original dealer-installed unit (installed in 1966) with the original York compressor. The car is still positive ground, the clock works, the one-speaker radio plays Petula Clark...
These photos are pre-restoration- no rust, no accidents.
The photos below show the work in progress: first removing everything (that exhaust system is not from the Mk 2):
The engine bay was left as "driver quality" on purpose - I have had too many concours cars that I was afraid to drive lest the engine get dirty. This is driven all year long provided the roads are dry.
Old Nov 11, 2018 | 09:00 PM
OK so she is restored but you started with a sound car ~ looks great!
Old Nov 12, 2018 | 12:39 AM
JeffR1's Avatar
That's incredible to find a car like that, it had to have been in a garage all its life, probably heated too since the brakes were all good.
Even the black leather and carpeting was kept out of the sun !
Old Nov 12, 2018 | 01:26 AM
sov211's Avatar
[QUOTE=JeffR1;1987598]That's incredible to find a car like that, it had to have been in a garage all its life, probably heated too since the brakes were all good.
Even the black leather and carpeting was kept out of the sun ![/QU
Correct! The car came to me from Winnipeg, where it was sold new at Motor Sales. Obviously it was used in the summer (for non-Canadians: Winnipeg summers are brutally hot), thus the dealer-installed AC; and I suspect it was not used in winter because there was no corrosion, not even on the chrome -and it was certainly garaged year round.
The carpets are original, completely unworn, even the driver's side, and they are still a rich black. No fading at all.
The brake discs were and are good, as you can see in one of the photos above, but all the rest of the brake system needed to be renewed including the booster unit. I put in a new water pump, all new hoses, a new SU electronic fuel pump (which looks identical to the original points pump -and it hides behind a panel in any case), and a Pertronix unit hiding in the original distributor. Those are the only modifications made, and they were made as a matter of reliability. The fuel tank was removed, cleaned, coated and replaced. I did fit a small filter between
the tank and pump. The compression was checked and it was 170 in all 6 cylinders. The transmission was leaking copious amounts from perished seals...I hesitate to say any more about the transmission because it is a long and sad story...oh heck...: my mechanic sent the transmission out along with another DG250 that had gone 200,000 miles. Of course I recorded my transmission serial number before it went and I verified it when the transmission came back.. The report from the transmission shop was that mine was perfect internally, needing only a new seal kit, which was done. But when the restoration reached the stage of putting the transmission back in (4 years later...don't ask...) it was immediately obvious that something was wrong. It simply did not shift properly. Out it came to go to a different shop. They took it apart, noted that the innards were worn , that the torque converter showed evidence of having been welded at least three times...ultimately, after two tries, they gave up; they just could not make it run properly. Have you figured it out? The case was my original case all right, but the workings were from the other, 200,000 mile car! The original shop had them both apart at the same time and mixed them up. As this was 4 years removed from the time the transmission went to the original shop, there was not much that could be proved. The other transmission, MY transmission in the other case, was long gone to parts unknown. To end the story, I bought a remanufactured unit from Whitehouse in England. You no doubt want to know what that cost (with shipping to the west coast of Canada) but I cannot bring myself to write it. In any case, the transmission shifts perfectly!
Old Nov 12, 2018 | 11:26 AM
JeffR1's Avatar
Maybe I'll see you at the fathers day picnic an Beacon Hill park some time, I'm only about 1 and a half hours form Victoria.
Old Nov 12, 2018 | 02:17 PM
Lovely car and a very nice restoration! I own property in eastern Montana, so I suspect that I have a pretty good idea of what Manitoba summers are like...
Thanks for sharing your story and pics.
Old Nov 12, 2018 | 04:37 PM
sov211's Avatar
That would be good - but a much better use of your drive down to Victoria would be for Jaguars on the Island in July...it is the largest Jaguar Show in North America every year!
Lars Thomas
Jul 15, 2013 11:48 AM
jawdoc
Dec 7, 2012 12:07 PM
FrenchJagman
Oct 19, 2011 04:00 AM
