340 Clutch Hard Line
Old Jul 29, 2022 | 02:42 PM
oxendine's Avatar
Default 340 Clutch Hard Line
The hard line from the slave to the rubber line looks to be 3/16. What is the size fitting that goes into the slave cylinder? I removed the line and fitting from my old engine and for whatever reason it will not screw into my new slave cylinder.
Old Jul 31, 2022 | 02:19 PM
NWG's Avatar
NWG
I believe that you will find that the hard line shaped end is slightly oversize on the diameter. The outer circumference of the end just needs a few thou trimming off so that it will enter the cylinder female thread, the threaded union will then follow afterwards. This pipe end oversizing will not allow the first thread of the union to enter the female thread.
The oversizing on the hard pipe end occurs when the pipe end has been formed with more pipe material in the nipple end than is required.
Old Jul 31, 2022 | 02:20 PM
NWG's Avatar
NWG
Old Jul 31, 2022 | 03:41 PM
Glyn M Ruck's Avatar
My clutch line cunifer pipe is terminated with one of these. I think the threads are UNF but Norman would know.
Bleed Nipple looks like this but with rubber protective cap
Old Aug 3, 2022 | 10:12 PM
oxendine's Avatar
Is there a supplier that sells the hard line from slave cylinder to flexible line that mounts on the head?
Old Aug 5, 2022 | 07:58 AM
Automec. That's what you will get from Barratts etc. They make in a variety of materials.
https://www.automec.co.uk/
oxendine
Jul 1, 2022 04:43 AM
Qvhk
Jun 6, 2017 10:41 AM
Vintagecarlover
Aug 16, 2015 10:14 AM
Nardoswiss
Oct 2, 2012 03:25 PM
gary Cox
E type ( XK-E )
Dec 13, 2011 08:59 PM
