Another transmission question - BW35 fluid type
Old Jun 12, 2019 | 02:10 PM
MXG's Avatar
MXG
Default Another transmission question - BW35 fluid type
All,
I have a 1967 3.4 MK2 with BW35 auto trans. I am ready to get my MK2 on the road and cant seem to figure out what transmission fluid my BW35 auto trans requires. Everything I read says it was designed for Ford Type F. I called SNG Barratt and they recommended Dexron II. I searched the forum and do not see this being addressed before.
Can I safely use Dexron II? The serial number plate lists a bunch of auto trans fluids - Including: BP type A, Mobilfluid 200, Castrol Grade A, Shell T.6. I think those are Dexron compatible fluids.
Any help would be appreciated.
MG
Old Jun 12, 2019 | 03:32 PM
Glyn M Ruck's Avatar
Fluids meeting Ford M2C33F or G have the correct frictional characteristics for your gearbox. i.e. quick clutch pack lock up. Dexron II will allow more clutch slip & delayed lock up. This can lead to excessive temperatures & burnt clutches. I don't know how tolerant the BW35 will be of the incorrect fluid.
Ford & GM had totally different design philosophy back then. Ford with small clutch packs that required to lock up quickly & GM with large plates that could take a lot of slip & slow lock up.
ATF's of different types have friction modifiers in them to suit the clutch pack size & friction material used. The correct fluid should be used. A smoother change (lower shift shock) is not necessarily the best change. Too much slip for the design will lead to clutch pack failure. Friction Modifiers allow controlled slip & lock up for a specific design.
Type F & Type G Fluids also offer far better wear protection of gears etc. than Dexron II.
Old Jun 12, 2019 | 04:09 PM
Nigel.W's Avatar
Hi Glyn, great explanation of the difference between the ATF's. When I fit back the Model 12 gearbox on the XJ I was planning to use this oil, https://www.opieoils.co.uk/c-1444-fo...-33fg-atf.aspx what do reckon of it? It has the Ford spec.
Old Jun 12, 2019 | 04:19 PM
Hi Nigel. I don't know the brand. It has the correct spec.
Old Jun 12, 2019 | 04:34 PM
Nigel.W's Avatar
Thanks Glyn, it has a good name in the UK - I'll give it a go.
Hartford6
Sep 4, 2018 08:40 PM
TilleyJon
Dec 28, 2017 04:00 PM
BKSinAZ
Feb 21, 2015 02:02 AM
rainbowboy
Sep 9, 2013 12:48 AM
