front windscreen
Old Jun 11, 2019 | 12:04 PM
PP3poplar3's Avatar
Arrow front windscreen
I am having problems fitting a Pilkington laminated front screen to a 3.8 mk2
Old Jun 11, 2019 | 02:28 PM
TilleyJon's Avatar
Welcome PP3poplar3,
What problems are you encountering ?
Glass size / shape, rubbers, chrome or all the above ?
Picture really help too.
Old Jun 12, 2019 | 05:24 PM
sov211's Avatar
I had exactly this issue...there was no way my experience glass man could get it to lie properly...the contours were wrong. In the end we refitted my original (easily) and still good but not perfect screen.
Old Jun 14, 2019 | 04:55 AM
Orlando St.R's Avatar
I believe that if you contact Pilkington, they will get you to take a series of measurements as to where it is dimensionally inaccurate and then make you another one. There was a series of articles in Jaguar World about having three attempts to get one to fit an E-type and they detailed that process.
Old Jun 15, 2019 | 12:06 PM
Glyn M Ruck's Avatar
I have recently fitted a new Pilkingtons Triplex screen to my S Type (same screen as Mk2). It's dimensions/shape were identical to the original.
The problems we had related to rubbers. There is a lot of ill fitting junk out there. We went through 3 sets to find a good fit.
You must find rubbers with correctly moulded corners otherwise they pucker.
The rubber should appear too large otherwise they pull up in the lower corners.
The screen should appear a little loose in the aperture prior to inserting the expander strip.
You must seat the bottom corners first or you will have trouble.
Seal glass & body side before inserting expander.
adamh149
Mar 25, 2015 04:52 PM
GypsyRover
Oct 23, 2014 02:46 PM
buddyluv
E type ( XK-E )
Sep 11, 2014 10:07 PM
osyris
Feb 14, 2013 07:19 PM
nm24
Jan 9, 2011 05:07 AM
