Brake Fluid
Sorry if this has been covered
What would be the best brake and Clutch fluid to use? Jag MK2 . New Master cylinders, Zues front callipers, standard rear with new kits
Ray
Ray
As I'm sure that you have no idea of the elastomers used, use DOT 4 or DOT 4+ Brake fluid. Flush every 2 to 3 years because it is hygroscopic. (absorbs water which lowers boiling point & can lead to corrosion).
Cheers Glyn
