Brake Servo - which one?
Old Nov 10, 2016 | 08:02 AM
davearkley's Avatar
Default Brake Servo - which one?
problem
My 66 s type seems to have a early brake servo fitted c19612 but the chassis number 1B2852 indicates that it should be the later unit c24707
where can I get one of these - I have tried the main suppliers
SNG DMG SC parts but no one has one in stock - but which one to use????
I have been told its a type 8 ??
Old Nov 10, 2016 | 09:05 AM
Dave,
I've moved your question from General Tech Help to MKI / MKII S type 240 340 & Daimler 1955 - 1967 forum. Definitely one for members with specialist knowledge of this model.
Also expanded the title to draw attention to it.
Old Nov 10, 2016 | 12:17 PM
SNG Barratt USA's Avatar
Former Sponsor
For an original replacement we are only able to recondition old units which we would be happy to do! Alternatively you may be interested in this Lockheed replacement: (see link)
Brake Servo - Aftermarket
This is available across all of our four branches..
Old Nov 11, 2016 | 07:41 AM
davearkley's Avatar
Hi Guys
I think I have located a recon unit available - its definately a later servo from the engine number and I have taken the old one off and checked.
thanks
Old Nov 12, 2016 | 03:45 AM
Homersimpson's Avatar
As an alternative if originality isn't an issue you can buy an LE10117 servo (3:1 Ratio), David Manners in Oldbury sell these for around £110.
Old Nov 12, 2016 | 06:45 AM
Jose's Avatar
To: SNG Barrat, what is the price to rebuild these brake servos / boosters? I have 3 that I want to rebuild. Thanks.
Old Nov 13, 2016 | 05:59 AM
davearkley's Avatar
Default s-type restoration
Hi Guys
Thanks for the input regarding the brake servo.
With such a comprehensive restoration I have tried to avoid compromises but I think its a trade off.
Originality against improvement.
Some of the new brake servo units are much better and give an improved braking system. I have the later servo fitted to my car and I have found a direct replacement which means that theres no modifications needed to the car. The later servo is an improved unit and should give adequate braking. I'm pleased that I dont need to modify the car. I have also taken out all the bits of wire that previous people have used to try and solve electrical problems.
Wiring is now fully working and original - This might sound a bit **** but the various bits of wire strewn around were not needed and looked terrible.
jaguarxfv8
May 3, 2017 06:54 AM
Sprayall
Nov 13, 2016 09:35 AM
alynmurray
Oct 30, 2016 06:49 AM
Homersimpson
Oct 24, 2016 01:18 PM
MediaBobNY
Oct 23, 2016 05:32 PM
