BW 35 Gearbox Help
Old Apr 22, 2014 | 04:01 PM
heyrouk's Avatar
Default BW 35 Gearbox Help
Hi I am restoring a 1965 MK2 3.4 Auto. On removing the torque convertor from the gearbox the pin in the attached picture fell out. The pin is 9/16 inch diameter and 2 inches long. I assume it fell out of the gearbox splined drive shaft as there is nowhere else it will fit. I have looked at all my manuals and spare parts catalogs but this part is not shown.
Can anyone help to identify what this is and if it is from inside the shaft which end goes in first.
Any help or pictures would be much appreciated.
Old Apr 22, 2014 | 05:48 PM
Welcome to the forum heyrouk,
If this is evidence of breakage (arrowed in red) .......
......... it could be sheared off the end of the splined input shaft.
Old Apr 26, 2014 | 05:46 PM
heyrouk's Avatar
Red face Problem Solved
Attachment 81410
Thanks for your interest. It appears the item I found is not part of the gearbox but is something that was dropped/left in the bell housing by the previous owner. I gained peace of mind from the following thread in another forum which has a complete, yes complete strip down of a BW35 in pictures.
BW35 strip and rebuild in pictures | Rover P5 Club Forum
Old Apr 27, 2014 | 10:20 PM
Anders Hansen's Avatar
The part appears to be from a DG 250 trans, like bigger Jags would have back in the day. It did fit in the hollow input shaft and had the dimpled end pointing forwards into converter.
Old May 5, 2014 | 08:50 AM
barrymk2's Avatar
Heyrouk, perhaps you can confirm that you have a one pce or 2 pce propshaft. many thanks.Subject of another post( gearbox swop bw35 bw65/66 & dg250)
barry
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
jjmiah217
Sep 28, 2015 09:09 AM
drbill
Sep 28, 2015 12:46 AM
