Cooling & Heating system re-plumb
Old Sep 26, 2021 | 12:15 PM
veroli's Avatar
Default Cooling & Heating system re-plumb
Hello,
I've recently acquired a 1962 Mk2 3.8. I twas stood for quite a few years so am slowly going through it and servicing/ replacing stuff.
Am about to tackle the cooling/ heating system but this is where it gets tricky. The car was originally a 2.4 but has been upgraded at some poin with a 3.8 litre engine.
The engine has come out of a track/ road racer so a few things have been modified. The heater is not connected up no pipes there.
thermostat has been blanked off at the front and there is some kinby pass pipe running from the water pump to the back of the engine.
So i want to put this back to normal, I've a heater pipe kit from SNG barratts and a full hose replacement hose kit, New thermostat and housing.
Does anyone have a full diagram of the standard cooling and heating system for the pipes what goes where and what etc.
Am struggling to find anything definitive. I jut need something relatively simple so i can connect all the hoses up to the correct places.
Many thanks
Old Sep 26, 2021 | 12:34 PM
Jose's Avatar
you'll need a Heater tap and a Heater box too, assuming they are not there.
Old Sep 26, 2021 | 12:39 PM
veroli's Avatar
the heater tap and box are there, just not connected to anything
Old Sep 26, 2021 | 03:08 PM
Jose's Avatar
go to my website and download the MK-2 shop manual which will have illustrations of all the systems. I have other MK-2 documents in .pdf format free.
https://classicstypeparts.webstarts.com
Old Sep 26, 2021 | 03:12 PM
JeffR1's Avatar
I didn't know you had all those goodies for sale on your web site Jose, I didn't even know you had a web site.
I need the two interior light covers on the centre pillars.
I suppose everyone else does too.
Old Sep 26, 2021 | 03:13 PM
veroli's Avatar
thank you Jose
i will take a look
regards
Old Sep 26, 2021 | 03:33 PM
Jose's Avatar
I had those light covers but sold them. Glad you like the site. S type and MK-2 share many parts but not the Heater tap. The S type heater tap is very difficult to find in good condition. MK-2 uses a different tap which I think is still available.
Since you have a 3.8 it will be easier to plumb it. Plumbing starts at the water pump.
I recently purchased new heater / coolant tubes in stainless steel for my S type, the ones that run behind the cylinder head to the heater box. SNG Barratt USA store has them new.
Old Sep 26, 2021 | 03:37 PM
Jose's Avatar
Jeff I have had the website for a number of years. Some parts sell quickly, others sit.
Old Sep 26, 2021 | 07:42 PM
Glyn M Ruck's Avatar
Strongly recommend you fit stainless steel heater pipes. Available from Barratt's. The mild steel pipes just rust through. The latest ones are real junk.
Have the heater matrix chemically cleaned.
Old Sep 27, 2021 | 08:24 AM
veroli's Avatar
yes i bought the stainless ones from barrats its just working out where all the hoses and pipes go
cheers
Old Sep 27, 2021 | 08:54 AM
Here you go ~ all you could ever want ~ Lin's site is excellent for Mk2 owners ~ I can only provide S type stuff & a little Mk2:
Heater:
https://valvechatter.com/?p=4681
The whole Mk2 project.
https://valvechatter.com/?p=2116
Old Sep 27, 2021 | 09:32 AM
veroli's Avatar
thanks Glyn,
this is a big help for sure, certainly startting to picture it better now.
just cant be sure the kit i bought from barratts includes the solid pipe that runs back down the side of the engine.
Great work from Lin though, briiliant reference
Old Sep 27, 2021 | 11:46 AM
Once you learn to navigate his site it covers everything. Navigation is sometimes a little counter intuitive but it's all there. Once used to it it is easy going. A complete restoration well recorded/documented.
Old Sep 27, 2021 | 01:07 PM
veroli's Avatar
thanks again for your help its starting to make sense now
Old Sep 27, 2021 | 04:21 PM
Jose's Avatar
[QUOTE=veroli;2446764
[/QUOTE]
yes it does, but no elbow hoses or clamps, only the pipes.
Old Nov 28, 2021 | 05:07 AM
veroli's Avatar
So heater box is back from refurbishment and upgrade and am ready to start putting it back in the car.
Cleaned out the control valve and put a new o-ring in and attached the cables.
However am not sure if i am missing something here if you look on the pictures there is a solid wire coming off the heather control valve in addition to the pull cable.
I cant work out what this attaches to or does ? or is it something that has been left on my particular control valve.
I've had a look on lins site and landie man but i cant see anything definitive for it,
Can anyone shed any light on it as i don't want to install it and it be connected wrong and have to take it all out as
once this is done i can drain the the whole cooling system and fit all the new pipes and hoses.
thanks everyone
Old Nov 28, 2021 | 09:08 AM
Is that not the heater flap control wire? Air flap B & tap controls are obvious
Old Nov 28, 2021 | 10:12 AM
Peter3442's Avatar
I had a look at my car. It's exactly as Glyn describes. The Bowden cable passes through the bulkhead to the heat control lever inside the car. The unsleaved wire goes from the. water valve to a lever on the heater box that moves the hot/cold flap inside. The arrangement is adjusted such that the flap and valve work suitably in synch. I wanted to take a photo, but it's not an accessible area. In particular, the flap lever is largely hidden behind the fan box.
Old Nov 28, 2021 | 10:21 AM
veroli's Avatar
thanks guys
its obvious now you show it and explain.
I didn't really have a lot to go on as it was all disconnected when i removed it, which always makes it harder putting it back together.
I'll give it another go tomorrow when the snow has gone and its above freezing in thw garage.
cheers again
tcap1047a
Feb 18, 2021 03:50 PM
Vee
May 23, 2019 11:46 AM
taylor6632
Apr 4, 2017 05:02 PM
edadoune
Mar 25, 2017 11:16 PM
2002Xtype
Oct 28, 2013 03:19 AM
