Cranking a 3.4 mk11 manually
Old Feb 24, 2015 | 01:05 PM
kennyjd's Avatar
Default Cranking a 3.4 mk11 manually
Hello, I recently purchased a Mk 11 3.4 auto, which has been standing in a garage for 23 years, overall it is in very good order, but I would like to be able to turn the motor manually to make sure it has not seized after sitting so long, however there is no crankshaft pulley nut, it is held on by a series of bolts and locking tabs, is there a tool for this? any suggestions welcome, regards Kenny.
Old Feb 24, 2015 | 10:56 PM
JeffR1's Avatar
Even with the locking tab in place there is enough of the big nut exposed to get a socket on there and a torque bar.
Remove the spark plugs and put a fair amount of penetrating oil in the bores _ leave it sit for a couple of days first.
When I get a chance I'll check to see what size the nut is.
When I'm timing the ignition, I use this method to carefully align the timing mark.
At any rate there should be big nut there _ maybe it's different for an automatic, but I can't see that.
Is it missing ?
#39 in the photo
Old Feb 25, 2015 | 11:14 AM
kennyjd's Avatar
Hello Jeff, thanks for the reply, once I got the radiator out of the way, I could see the arrangement and took off the locking tab that let me get a socket on the nut, I have had oil down the bores for a couple of weeks, so much to my surprise the motor turned without any effort, so I will carry on from here, best regards Kenny.
Old Feb 25, 2015 | 03:30 PM
JeffR1's Avatar
Well I'm glad you found your nut ! or bolt rather _ I went and checked today for the size and it's 1 5/16 inch's.
If you haven't already done so, turn it over several times to make sure none of the valves stick.
It would be unlikely they would, but it if one did, it would be disastrous.
JWheeler
Nov 22, 2019 08:28 AM
picard
Sep 19, 2015 08:13 PM
tsimms7
Sep 15, 2015 12:43 PM
joesoap
Sep 10, 2015 01:09 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
