Daimler MK2 differences
Old May 11, 2015 | 09:42 AM
ViolentBlue's Avatar
Default Daimler MK2 differences
I bought a pair of MK2's, one a stripped body in very solid condition and the other body rotted, but with full interior and running gear.
Just found out the solid body is a Daimler.
besides the grill, what else is different between the 2 cars?
will the sheetmetal on the front of the Daimler accept the MK2 grill? or does it need to be cut out and replaced?
Old May 11, 2015 | 12:28 PM
DaimlerMK2's Avatar
grill should be ok,
seat mounts are different,the 2 light on the rear inside are,in jag but not Daimler,
head lining,rods in jag not in daimler and no fixings for them in Daimler,
gear box tunnel in Daimler bigger than jag,
vin plate on inner wing on Daimler,and fire wall on jag,
plus I bet lotsof things I have mist.
Old May 12, 2015 | 02:55 PM
Jose's Avatar
if it is the Daimler version of the MK-2 then it also has a V8 engine with one carb.
Old May 12, 2015 | 06:44 PM
sov211's Avatar
Don't forget the light plinth on the trunk lid....
Old May 20, 2015 | 10:03 AM
littlelic69's Avatar
The Daimler has the V8 engine with twin carbs. It also has a radiator with a built in oil cooler below the main radiator body. The front seats are well different and the headlining is solid without listing wires. The badging on the boot lid is different as are the boot plinth and radiator plinth and radiator fan ducting. I have been told that the quarter lights on the front doors should have a push button lock to prevent opening from the outside. (Mine does not have this feature)
Old May 21, 2015 | 09:01 AM
so if I swap all these things from the MK2, shouldnt be a problem?
Old May 21, 2015 | 01:19 PM
DaimlerMK2's Avatar
up to you,
but someone could still tell,
the way the front seats mounts you will allways see them unless you weld in the jag ones,
Col. Sandurz
Sep 28, 2015 12:49 PM
vicom
Sep 17, 2015 03:32 AM
prettydaim
Sep 10, 2015 04:27 AM
1964Daimler
Sep 9, 2015 11:28 AM
Harry Dredge
Sep 5, 2015 02:44 AM
