Examining a 1961 MK2 Engine
Old Nov 21, 2018 | 10:56 PM
Treozen's Avatar
How is the oil pressure hot? That knock is quite pronounced but if it lessens as temperature rises & clearances normalise it's unlikely a bearing. Your diagnosis is probably correct.
Oil pressure at idle is around 20psi, and 40 - 45 at 2000 RPM - this is according to the in-dash gauge. The knock is easy to hear upon startup (like the video) but after the car has been running and gets to around 60 degrees C or 140 F (again, by the gauge) the knock is there, but would be easy to miss if you were not listening for it.
Old Nov 22, 2018 | 07:18 AM
Glyn M Ruck's Avatar
That's fine. Seems the bottom end of the engine & oil pump is healthy. I find myself having to re calibrate with these old cast iron block, very long piston skirt, long stroke engines. Piston slap in the modern aluminium block, Alusil bore, ultra short piston skirt engine sounds quite different. (it's a hollow tapping sound)
A bearing knock (crank or small end) will not reduce as the engine warms up. It will tend to increase.
Old Nov 24, 2018 | 02:10 AM
Treozen's Avatar
Well, I'm certainly hoping that it is a condition I can live with for a while. The prospect of a rebuild is itself a tad unpleasant, but I'd feel better about it if the engine was also otherwise a ruin of worn parts, sludge-filled oil passages and asthmatic compression - but as it is, I'm continually surprised at the engine's condition. I've never looked at an unknown mileage engine, presumed to be in excess of 100K, and found it so clean. The oil is golden, I can find no hint of sludge, or build-up on any internal parts I've so far examined, the breather tube was clean and free of any oil, compression figures were enviable for an engine in any condition and best as I can tell, it doesn't even leak any oil - nada - nothing - nothing on the ground, nothing from the rear seal (best as I can tell). The only issues I can find are piston slap that diminishes with temperature and a curious volume of white smoke that although lacking all other indicators, makes me suspect a head gasket. I'd really hate to have the engine torn down if its only real problem is an annoying knock that goes away after 5 minutes.
Old Nov 24, 2018 | 08:08 AM
TilleyJon's Avatar
I would highly recommend a leak down test to identify the slapping cylinder, then put a boroscope down the spark plug hole to see what scoring there is in the bore.
The piston slap will only get worse and there is a possibility of breaking the piston skirt, if this ends up in the crank (which it will if it breaks off) you can guess the possibilities !
I personally would not continue driving a car with piston slap as this will almost certainly end up with a higher rebuild cost and a possibility of a wrecked crank and other damage should the piston drop part of the skirt in the crank.
Obviously this is my personal opinion and you may get away with it for quite a long time, but I would make sure that there is no bore damage already happening before continuing to drive it at the very least.
Old Nov 25, 2018 | 07:22 AM
Homersimpson's Avatar
I would also check that the cam follower sleeves haven't come loose in the block and also check the valve clearances and that the shims are the correct size (width not just depth as I've seen thicker shims from other cars used in the past when the standard jaguar shims weren't enough).
Old Nov 25, 2018 | 08:39 PM
Treozen's Avatar
Piston slap seems to be one of these issues that has a consensus on how annoying it is, but no such agreement on how damaging it is - with reports of successful mileage 50K+, to dire implications if the engine is so much as started, being equally plentiful. As it stands today, the car is not a driver, but I'd like it to be fairly soon. I have a local mechanic who claims to be an XK expert - he has rebuilt several, and one was a seized motor from an XKE, and he has that one purring like an angry kitten - So I'll get his take on appropriate next steps.
The issue I have with a leak down test, is that the compression test provided no evidence of a problem, if anything it suggested a very healthy engine. My general understanding is that a compression test will indicate that there is a problem, whereas a leak down test will tell you what the problem is. In my case however, the compression test did not indicate leaks or issues at all, so if there is no "leaking" occurring, I'm not sure if a leak down test will prove valuable.
Yes - agreed - if the motor goes in for any sort of work, I'll have them do all the reasonable checks and adjustments while they have it opened up.
Old Nov 26, 2018 | 01:19 AM
TilleyJon's Avatar
This was the point of my saying it "CAN" happen, it is a gamble, ask your XK expert if he can guarantee that no further costly damage will occur, and then you can make your own decision.
Doing a leak down test is much more accurate than a compression test, it gives you a percentage figure and the pressure is constant not reliant on the maximum compression over several stokes of the piston, my comments on doing this were in reference to checking if/or which piston could be slapping so you could check for bore wear, again to ascertain if any or how much damage may be occurring.
Obviously this is all my own opinion and best advice I can give you with the information you have given.
gene61jag
287
Jan 17, 2022 06:12 PM
JoeSantana
93
Nov 18, 2017 10:08 AM
rtipping
May 18, 2014 09:41 AM
barrymk2
May 5, 2014 08:11 AM
