Ground Near Coil - What Type of Screw? Brass or Galvanized or????
Old Aug 25, 2015 | 02:04 AM
1964Daimler's Avatar
Default Ground Near Coil - What Type of Screw? Brass or Galvanized or????
There's a loose ground wire near the coil. I've tired to screw it back onto the fire wall (Yes, I scrapped the firewall and cleaned the area with spray).
But it won't stay. So I must not have the right sized screw. What size is acceptable, and what type of metal? Brass? Zinc? Galvanized?
And should I use a washer between the screw and the ground?
( I mustbe making progress. Neighbors are coming out to look at the car, and I smell of gas and grease even after washing up.... )
Attached Thumbnails Ground Near Coil - What Type of Screw?  Brass or Galvanized or????-coil.jpg   Ground Near Coil - What Type of Screw?  Brass or Galvanized or????-coil3.jpg
Old Aug 25, 2015 | 04:59 AM
redtriangle's Avatar
Check to make sure there is no captive nut on the other side. If so, its probably 1/4" UNF screw that's required. If not, any self-tapping screw would do. Using a serrated washer may help in making a good ground connection. Check for continuity to ground with a multimeter after fitting.
Old Aug 25, 2015 | 12:00 PM
Jose's Avatar
I've only seen brass bolts used at the Battery Holdown in S types, not even screws.
I have seen Brass Nuts used in Jaguar manifolds, but nowhere else.
I would replace the screw or bolt with a stainless steel bolt of the correct thread.
Old Aug 25, 2015 | 02:49 PM
MK2's Avatar
MK2
I don't recall for sure, but I think that uses a #10-32 machine screw. Phillips.
Lin
Old Aug 25, 2015 | 03:58 PM
JeffR1's Avatar
It almost looks like a brass wood screw _ the photos are a bit out of focus and the threads can't be seen clearly.
At any rate the upper part of the shank doesn't look threaded so I would think by the time the under side of the head makes contact with the ground leads, all of the thread will be on the other side of the firewall.
If you try and tighten it, it will just go around in circles.
Old Aug 25, 2015 | 04:46 PM
Fraser Mitchell's Avatar
If its on the bulkhead, there should be a captive nut behind to take the screw. Jaguar would have used a cadmium-plated screw, with an anti-shake washer. Nothing wrong with that inside an engine compartment, although brass or stainless is better.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
