HELP - Installing MK2 dash
Old Aug 4, 2024 | 01:52 PM
85lc's Avatar
Default HELP - Installing MK2 dash
I am trying to install the dash in my MK2. It is the original dash that has been revaneered. It is too long to fit.
All the wood trim in in including the two veneered covers on the A post.
Do I have to remove these pieces to install the dash??
Old Aug 4, 2024 | 02:31 PM
Fraser Mitchell's Avatar
Not quite sure what you mean by "dash". The Mark 2 dash consists of the all the various parts that together make up the dash. I suspect you are referring to the screen rail capping which sits atop the two veneered facia assemblies, one for the cubby box, the other for the speedo and revcounter. In the middle is the instrument and switch panel that folds down.
Perhaps some photos to show us your problem. It's a very long time since I assembled the interior in my Mark 2, I think it was 1986 or 1987, so my memory has faded on the order in which the varaious components are fitted.
Here is the front body fittings drawing of parts courtesy of SNG Barratr. I hope they won't mind helping out a fellow Jaguar enthusiast.
https://www.sngbarratt.com/English/#.../assembly/2164
Old Aug 4, 2024 | 04:40 PM
Glyn M Ruck's Avatar
Old Aug 4, 2024 | 05:44 PM
Mr Barratt does not mind. I use his stuff all the time. I asked him when I met him. I went to the UK prior to seriously starting my restoration & personally met the head honchos of all my suppliers like David Manners, Jon Skinner etc. (Jon for Jonathan. John was his Dad after whom the company is named).
Old Aug 4, 2024 | 07:35 PM
Bill Mac's Avatar
I think 84lc is referring to the screen rail.
Yes, it is a good idea to remove the A pillar veneered covers.
That will give you some 'wiggle' room.
They can be replaced after the screen rail is fitted
Old Aug 5, 2024 | 03:08 AM
Cass3958's Avatar
Yes remove the "A" pillar wood but even then I found it was a struggle if you have the screen fitted. The back edge hits the screen whilst the side hits the "A" pillar and it some point you just have to force it in that last fraction of an inch on the edges.
Old Aug 5, 2024 | 05:32 AM
My windscreen was in. I'm not sure which way you handle the "A" pillar cappings makes much difference. There comes a time that you just have to give the screen rail a good shove. We got mine in with zero damage.
Excuse red push of cellphone camera
Approx colour Cellphone
Approx colour cellphone.
Canon Powershot G10 (accurate but I suffer from tremor so at the camera max antishake limit ~ would be sharper on tripod)
Rest in the link in my signature.
Old Aug 6, 2024 | 03:43 AM
michaelgilbert's Avatar
That is a slightly painful job. The top does fit, and I get the fitment technique wrong every time until I finally get it. It kinda rolls into place. If you try every possible combination of things, one will work! Unfortunately it doesn't just slide in. Only the Poms could design some things the way they did!
Old Aug 6, 2024 | 04:39 AM
85lc's Avatar
Thanks, that is what I have experienced but haven't found the right way to get in in. I didn't remove it so don't have that experience. It is simply too wide to slip in, roll in, tec.
rickysxk8
May 30, 2024 04:00 PM
cdg66mk2
May 23, 2024 06:37 AM
FrankC44
Apr 17, 2023 09:06 AM
deelcee
Feb 22, 2022 04:21 PM
Fredclum
Aug 24, 2020 08:25 AM
