Idle speed
Old Mar 14, 2024 | 01:44 PM
Rishi's Avatar
Default Idle speed
The journey begins. Already found a couple of little things I need to investigate.
First the idle speed. Car starts well and the automatic choke functions OK. I do have an override switch but I have not needed to use it.
After a longish drive where the engine performed beautifully I stopped for petrol and noticed the engine was idling at a little over 1000 rpm.
Filled up with petrol and started again and now the idle was around 500 rpm. What would cause the idle not to drop? I tried blipping the throttle but it still just came down to 1000.
When I stopped the car a couple of times I have noticed a little dieseling, not sure if this is related.
Any idea's how to diagnose?
Old Mar 14, 2024 | 01:56 PM
hueyhoolihan's Avatar
just a guess, but...
a dirty throttle linkage can play havoc in attaining a consistent return to idle and IME the most likely and, fortunately, the easiest to fix. the next most likely culprit would be a worn out throttle shaft and/or the bushings in the carb bodies. not so easy, and much more expensive to fix. could even be in the accelerator-pedal-to-throttle-shaft connection. i've had success, albeit probably short-term, on occasion by simply lubricating the moving parts associated with the accelerator, from cabin to carb, and driving it for a while.
dieseling, i would think, is a separate issue and can be caused by many things. here's some info on it: https://en.wikipedia.org/wiki/Diesel...20and%20valves.
Old Mar 14, 2024 | 02:03 PM
Glyn M Ruck's Avatar
The 2 throttle return springs are very light on these cars & might need replacement. Does the car have a CR of 9 to 1 with 9 to 1 pistons & a slight head shave? What Octane of fuel did you use? If Idle is high and Octane is borderline you can suffer run on. You have got to get the idle to settle below 1000RPM. Max 700RPM. That Wiki article on "dieseling is pathetic".
Old Mar 14, 2024 | 02:26 PM
Peter3442's Avatar
Agree with Huey. Check the springs. There may even be one missing or wrongly attached.
Old Mar 14, 2024 | 02:34 PM
Rishi's Avatar
The engine is a 9:1.
The previous owner was using 95 octane. I immediately filled up with 98.
I will check the springs.
I will lubricate the whole chain from pedal to carb as that is easy. The carbs have been rebuilt.
Luckily a Haynes manual was included in the deal.
Old Mar 14, 2024 | 06:32 PM
JeffR1's Avatar
Worn throttle shafts as mentioned will cause dieseling because if they cause the butterfly valves not to fully shut after switching off the ignition, fuel and air will continue to enter the engine.
This will cause dieseling.
Too rich a mixture as well _ what do your plugs look like after a long drive ?
Old Mar 14, 2024 | 07:42 PM
Default Throttle springs.
It would be extremely difficult to muddle the throttle springs. They vary considerably in length. Short top location, long bottom to oil filter housing bracket. Getting these cars to settle to proper idle requires every point of the linkage to be nice & free. My 8 to 1 CR engine will run on if it does not settle to correct idle speed. I won't use the language used by a colleague, criticising the linkage on the Register.
On no account use stronger springs. You will increase carb wear.
Old Mar 14, 2024 | 08:05 PM
Refresh page for extra images.
Gus
Jul 25, 2016 08:20 PM
daver791
Apr 2, 2015 03:21 AM
jleuz1
Sep 17, 2014 06:39 PM
petemohr
Mar 30, 2014 02:48 PM
barefoot
Aug 25, 2013 12:15 PM
