Leaking from behind dash onto floor
Old May 14, 2024 | 08:20 AM
Rishi's Avatar
Any suggestions for a suitable sealant?
Old May 14, 2024 | 08:38 AM
Glyn M Ruck's Avatar
Sikaflex or Loctite 480
Old May 14, 2024 | 08:53 AM
Den Braven also makes a product/sealant.
Old May 14, 2024 | 10:53 AM
Peter3442's Avatar
I'm not sure about it in this application, but a flexible sealant/adhesive that I've used and found to be outstandingly good in various domestic applications is Geocel Works. It has the particular advantage that it doesn't require surfaces to be dry.
Old May 14, 2024 | 01:44 PM
Den Braven makes sealants that can be applied to wet surfaces or not completely dry surfaces.
Old May 19, 2024 | 04:31 AM
Rishi's Avatar
I have decided not to mess around and get a new seal for the windscreen. The recommendation from this thread are the COH Baines seals. Before I order is this the best chance I have for a properly fitting seal? I would rather spend a few more euro on a seal that will fit nicely.
Old May 19, 2024 | 02:26 PM
Yes in my case. Properly moulded with no puckering on corners.
wymjym
Mar 22, 2024 09:42 PM
anyoldiron
Sep 9, 2019 10:25 AM
mefoote
Feb 22, 2013 07:27 AM
jevs
Sep 29, 2009 06:32 PM
