MK2 3.8 Moss Gearbox Observation Hole
Old Dec 1, 2013 | 11:47 AM
MK2's Avatar
MK2
Default MK2 3.8 Moss Gearbox Observation Hole
Hello,
Is there supposed to be a rubber plug to cover this hole in the bell housing? I cannot find a part number if there is. can someone help?
Thanks so much.
Lin
Attached Thumbnails MK2 3.8 Moss Gearbox Observation Hole-bellhousing-hole.jpg
Old Dec 1, 2013 | 02:50 PM
Jagfixer's Avatar
Don't know of a plug. This is where you set the timing.
Old Dec 1, 2013 | 03:55 PM
MK2's Avatar
MK2
Default mK2 3.8 Moss Gearbox Observation hole
Jagfixer " Don't know of a plug. This is where you set the timing."
I thought that was on the lower side where there is a cover to be rotated over the hole if I recall correctly. Seems odd that there would be an open hole all of the time. That is big enough for a whole family of mice to move in :-)
Lin
Old Dec 2, 2013 | 05:51 AM
Jose's Avatar
just a thought because I could be wrong, but I think what is missing there is a plastic "grille", or a "vent grille" if you will. Could be a "Breather Vent hole".
The reason I say that is because I have seen Borg Warner transmissions used in Jaguar, which have a similar opening on the bell housing although on a different location, the BW66 for example, it has two similar rectangular holes at 6:00 o'clock where two vent grilles snap on.
so if you cannot find the proper part, you might get one from say, a BW66 tranny and trim it to fit.
Old Dec 3, 2013 | 05:27 PM
Jagfixer's Avatar
I've seen the sliding aluminum cover on the 68-71 XJ6 but every time I looked under the bonnet at a MK or 120-150 for any type of service, I have never seen the cover. It is not in any of the build or parts books I have from 1948.
boiler
US Southwest
Dec 20, 2025 12:38 AM
JaguarLover101
48
Jun 12, 2023 10:28 AM
MrWhite
33
Oct 22, 2015 10:29 AM
3lvis
Oct 1, 2015 01:56 PM
