mk2 coupe
Old 07-02-2015, 11:11 AM
DaimlerMK2's Avatar
Default mk2 coupe
Hi all
made a start on my 2 door mk2,
going to run 4.2 v8,manual 6 speed box and stand alone ECU,and
run on BMW 19" wheels.
Old 07-02-2015, 07:16 PM
Stoney85's Avatar
I already love this!
What are the plans with regards to suspension and brakes?
Old 07-03-2015, 01:42 AM
DaimlerMK2's Avatar
back will be ha4 axel,with a 288 diff from a v12 irs,5 link coilover springs,bigger
vented disc,
not sure about the front,but bigger disc xjs uprights may use front clip but weld it in place,
Old 07-10-2015, 12:12 PM
DaimlerMK2's Avatar
4.2 na engine and 6 speed manual box in,
Old 07-10-2015, 03:26 PM
Doug Dooren's Avatar
Dave, I assume this is the Daimler? I like the coupe profile a lot. The front window frame extension should be pretty simple - simply braze a channel extension forward of the rear vertical piece and rechrome. Not sure what you're planning for the rear - fixed glass? If you go that route I'd recommend sourcing some mile steel channel that comes close to original profile - that way you can weld which is a lot easier than a torch. Keep us posted on your progress and hang in there - you have a lot of work ahead of you.
Old 01-13-2016, 11:15 AM
DaimlerMK2's Avatar
Default mk2 2 door coupe
Old 01-13-2016, 12:20 PM
DaimlerMK2's Avatar
bit more done on the 2 door
Old 01-13-2016, 12:21 PM
DaimlerMK2's Avatar
Old 01-13-2016, 12:24 PM
DaimlerMK2's Avatar
Old 01-19-2016, 02:22 PM
58mk1x2's Avatar
Default brake set up
hi dave , would you mind telling me what the master cylinder / power booster are off or is it some of your handy work .
cheers
jim.
Old 01-20-2016, 02:56 PM
DaimlerMK2's Avatar
Hi Jim
its from a xj 308 I think,1998/99 car
58mk1x2 (01-21-2016)
Old 04-07-2016, 07:57 PM
loftymk1's Avatar
Default rear wheel arches
how have you made the rear wheel arches are they steel like the look
Old 04-08-2016, 09:41 AM
DaimlerMK2's Avatar
hi loftymk1
yes steel,they are front repair arches,
Old 04-08-2016, 10:41 PM
loftymk1's Avatar
thanks great project were would be best to buy these arches don't think I can get these I ausy
Old 04-09-2016, 04:54 AM
DaimlerMK2's Avatar
I got them from ebay,
loftymk1 (04-09-2016)
Old 05-07-2016, 06:38 PM
loftymk1's Avatar
hi just wondering what distance the new arches are from were the rear spats use to sit im thinking i will build my own thinking about 60 mil or 2.5 inches from were the old sat on
thanks
Old 05-10-2016, 11:37 AM
ViolentBlue's Avatar
now that is very cool
maybe one day i'll do something similar to one of my MK2 shells.
Old 05-12-2016, 07:56 AM
peterg19's Avatar
Looks great Daimler
Keep us updated with more pics please
Old 09-29-2016, 12:27 PM
DaimlerMK2's Avatar
I did this
58mk1x2 (10-04-2016)
Old 09-29-2016, 12:31 PM
DaimlerMK2's Avatar
and did this
Quick Reply: mk2 coupe
